Go to Post If I was making this I would want to not have to use anything smaller than a 3/16" end mill, but 1/8" would be acceptable. Anything smaller and I'd tell the designer to go play in traffic. - Cory [more]
Unread 03-09-2014, 03:03 PM
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Vision Targeting: Dilate
Is there an equivalent of the openCv structure element "dilate" in Java's version of NIVision?
Unread 03-10-2014, 09:02 PM
Re: Vision Targeting: Dilate
The Dilate is an input to Morphology function.
Specifically, the imaqMorphology function or the imaqGrayMorphology function if the image is still grayscale will take in a method that can be dilate.
I don't know if that is wrapped for Java.
Greg McKaskle
Unread 03-15-2014, 01:08 PM
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Anyone? We need it to detect hot goals
E/ i found this in NIVision.java
    //  Morphology functions
    //IMAQ_FUNC int IMAQ_STDCALL imaqGrayMorphology(Image* dest, Image* source, MorphologyMethod method, const StructuringElement* structuringElement);
E/ can anyone post the list of constants for MorphologyMethod and StructuringElement? if I'm rewrapping the entire NIVision library might as well throw in erode as well
I'm going to see if i can rewrap this
E/ my copy of windriver has no license -_-
E/ found them here http://zone.ni.com/reference/en-XX/h...raymorphology/
E/ for open sourcing purposes, here is NIVision.dilate(). If anyone knows how to remove the while loop and convert the 0 into a [count][count], LMK. If you want to use this, you have to rebuild the wpi libraries and add this in image/NIVision.java
    private static final int FN_DILATE = 2;
    private static final BlockingFunction imaqGrayMorphologyFn = NativeLibrary.getDefaultInstance().getBlockingFunction("imaqGrayMorphology");
    static { imaqGrayMorphologyFn.setTaskExecutor(taskExecutor); }
    public static void dilate(Pointer dest, Pointer source, int count) throws NIVisionException {
        assertCleanStatus(imaqGrayMorphologyFn.call4(dest.address().toUWord().toPrimitive(),
                                                source.address().toUWord().toPrimitive(),
                                                FN_DILATE,
                                                0));
        if(--count > 0){
            while(count --> 0){
                                                        FN_DILATE,
                                                        0));
