Go to Post Look for metal shavings in a pwm port; that's caused us to crash plenty of times. - Gary Dillard [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Unread 16-03-2014, 14:03
alexander.h's Avatar
alexander.h alexander.h is offline
Lead Programmer, Captain, Driver
FRC #3975 (The Dragons)
alexander.h has a spectacular aura aboutalexander.h has a spectacular aura aboutalexander.h has a spectacular aura about
Exclamation Rule R23
Hello! I've been looking through the manual for any last-minute modifications we might need to do and I came across rule R23 concerning the bumpers.
R23
BUMPERS may not be articulated (specifically, R23 is assessed relative to the FRAME PERIMETER).
Can someone please give me the exact definition of what the word "articulated" means in this case? Thanks!
2012 - Rebound Rumble - Montreal Robotics Festival - Qualified 15th - Semifinalists thanks to 3379 and 3710 (Record : 8-8-1)
2013 - Ultimate Ascent - Montreal Robotics Festival - Qualified 33rd - Dean's List Finalist : Yazid Djenadi (Record : 4-8-0)
2014 - Aerial Assist - Montreal Robotics Festival - Qualified 9th (Record : 6-4-1)
2015 - Recycle Rush *** I predicted the game ***
Unread 16-03-2014, 14:19
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Re: Rule R23
"Articulated" means moving the bumpers relative to the frame perimeter during the match.
Relative to your frame perimeter, the bumpers must be in a static position during match play. You can however take the bumpers on or off after matches, or switch the color if you have reversibles, that is allowed.
If you have questions about your specific design, please post pictures and/or descriptions.
Unread 16-03-2014, 14:22
Re: Rule R23
Well, we're using hinges at bumper corners to easily put them on, so you could say that they are slightly articulated off the robot. However, when we put them on during the match, the bumpers are perfectly static. Will this pass?
Unread 16-03-2014, 14:24
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Re: Rule R23
See Q198 in the FRC Q&A.
In the future, go to https://frc-qa.usfirst.org/Questions.php, click on a category (and, optionally, the filter), then click the Search button for each section of the rules. It all makes good reading. (It's a place not really obvious unless you see it mentioned.)
Unread 16-03-2014, 14:27
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Re: Rule R23
So if you have bumpers that are attached to pnumatics, that extend out and in the game. That is most likely illegal right?
Re: Rule R23
So I guess that we're good! Thanks for the clarification!
Unread 16-03-2014, 14:28
Re: Rule R23
In theory, that's the idea.
Unread 16-03-2014, 18:08
FRC #1153
Rookie Year: 1900
Re: Rule R23
Well, I was just answering what the word "articulated" means in the rules, not if your hinges are okay. You still have to follow the "4.6 BUMPER Rule" section.
Unread 16-03-2014, 18:11
Re: Rule R23
Don't worry, I believe that the rest of the rules were followed. And what do you mean by "if our hinges are okay" ? How could they not be okay?
Unread 16-03-2014, 18:27
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: Rule R23
This is just my interpretation of the rules. For the record I think having a hinge on the bumpers for easy access should be fine as long as you secure it before the match.
Rule R32 about articulated bumpers is in the Robot section of the rules, not the Game section of the rules. Therefore, it is a robot requirement. It does not say that the bumpers may not be articulated during match play, it says that they may not be articulated, period. To me, that implies that ANY articulation is illegal, whether or not it's powered and whether or not it occurs or can occur during a match.
My understanding from your comments is that the hinges allow easy access/installation, but you have something additional like pins or bolts that you use to secure them to the frame perimeter so they cannot "hinge" during a match.
If that is the case, the hinge AND whatever pins you are using to fix the bumpers to the frame perimeter are both necessary parts of your bumper mounting solution. Without both of those, your bumpers aren't fully installed. With them installed and fixed, they can't articulate so they aren't articulated.
It would be akin to someone who has a bumper mounting system that drops into slots, and then the pin through the slots. If you just drop them in and then go to inspection, they'd fail you for not being a rigid and robust mounting system, but it's never designed to compete like that because that's not the complete mounting system.
Unread 16-03-2014, 18:33
Re: Rule R23
I see ... thanks!
