Go to Post Of course our robot can fly! - Bill_B [more]
Unread 17-02-2003, 23:40
Scooter's Avatar
Scooter Scooter is offline
Galactic Doughnut!!
#0418 (Purple Haze)
Scooter will become famous soon enoughScooter will become famous soon enough
Send a message via AIM to Scooter
Angry Help!!! Transmission problems
Today, we got our robot going, set it down to drive, and well, it dind't. What happens is that the bot will move about 6 inches or so and then the 40 amp curcuit brakers will cut off. We have tried checking all of the connections for binding, greasing everyting, etc. We are running the drill motors through the supplied gear boxes directly to 8 1/2 in dia. wheels. We have a chain connecting the drive wheels to the rear ones to form a 4wd system. We have also tried removing the chain to make it a 2wd system.
Any suggestions?
Thanks,
Bill B.
"Those who think that they know everything are especially annoying to those of us who do."
Unread 17-02-2003, 23:49
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
40amp breakers
We had a similar problem with our 40amp breakers. We found that one breaker had gone bad and we replaced it with an extra one.
Unread 18-02-2003, 21:47
Scooter,
Does the robot run when you lift it off the floor? If it does then your wheel axle(s) is probably binding. Since you are using the drill motor transmission combo, is the trans firmly selected into one gear or the other? Start with the simple stuff, disengage the drive wheel gear from the rest of the drive system and see how easy it is to turn the wheels. If that seems OK then see if you can drive the drill motors without being connected to the drive wheels. If that is OK then the gears are not meshing right. I suspect you will find a mechanical problem is the cause if you are using the supplied FIRST drive system. Many teams have reported over tightening causes the parts to crack.
Let us know what you find.
Unread 19-02-2003, 09:24
Jessica L. Jessica L. is offline
None #0343 (Metal-in-Motion)
Jessica L. is an unknown quantity at this point
Send a message via AIM to Jessica L. Send a message via Yahoo to Jessica L.
we know the feelin
We've been having a lot of problems w/ our transmission too. I think almost everyone on the team knows basically how to change it b/c it messes up SO much.
Hope everything works out!
~Jessica~
Unread 19-02-2003, 15:33
Mark Jones Mark Jones is offline
Engineer - Team 343 MIM
FRC #0343 (Metal-in-Motion)
Mark Jones will become famous soon enoughMark Jones will become famous soon enough
Send a message via AIM to Mark Jones
Air is the problem....or lack of it....or is it lack of power??
We're using pneumatic cylinders to shift our two speed transmission. The cylinder is controlled by a single acting solenoid valve. When power is removed, the cylinder will return to its original state. Therefore, if we are traveling 13ft/sec when the control power is interrupted, the transmission will shift into low. NOT GOOD. We therefore changed the solenoid valve to a double acting type to eliminate any problems.
Another thing to all teams...Make sure you are checking your mechanical connections very well after every match. This years game is very physical and the playing field is very stressful on your machines. Bots will experience significant vibration as they travel over the ramp, especially if they have a fast machiane. Our students have been running our robot around during the last few days for hours at a time, catching air over the ramp, destroying crates and basically pushing it to its limits. It has really held up very well except of some lose connections. Take the time after every match to go over your machine and check your connections.
Good luck to all!!
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Joystick problems archiver 2001 3 24-06-2002 02:40
Radio problems -- not archiver 2000 1 23-06-2002 22:23
322 Three speed transmission. dkeith Robot Showcase 8 10-06-2002 22:33
Which teams are using a transmission this year Todd Derbyshire Scouting 10 08-04-2002 10:21
