Go to Post Publishing your code and designs = good. - MrRoboSteve [more]
  #31   Spotlight this post!
Unread 14-03-2014, 22:50
Jared Russell's Avatar
Taking a year (mostly) off
Re: Hot Goal Timing Issues
Originally Posted by Jared View Post
It seems to be a lot more consistent that week two, which, at Groton, ranged from really accurate to not changing at all.
I picked four matches from the Howell District competition (Q 35, 42, 36??) to watch, and it still seems to be a little bit unbalanced.
The average time before the goal lights in these four matches was 1.24 seconds, the average time on the first goal was 4.95, and the average time on the second goal was 3.8 seconds. I assumed the end of autonomous was exactly 10 seconds after the first frame where a robot moved.
It may just be coincidence, but it seems that the earlier matches from today were much better.
This suggests that the situation is exactly the same as it was in Weeks 1-2.
  #32   Spotlight this post!
Unread 15-03-2014, 00:44
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Originally Posted by Pat Fairbank View Post
Can anyone at an event this week verify that this has been fixed?
From the one brief look I took at the Sacramento Regional webcast, there doesn't appear to be any difference from last week.
At North Carolina both 1) and 2) still seem to be the same. The hot goal is lighting up about 1-1.5 seconds after the start of the match and not switching until the clock is on 4 seconds remaining, or very close to it.
Still appears that robots are about a second ahead of match clocks (e.g. Robots are dead with about 1 second remaining in teleop).
All of this is from a naked eye test; no analysis or frame by frame study.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
  #33   Spotlight this post!
Unread 15-03-2014, 09:30
Jared's Avatar
Jared Jared is offline
To me, it seems better than Groton was. Sometimes, robots would shoot the ball before the hot goals lit up, and other times, one side would remain lit for all of autonomous. I have only watched about 15 week three matches, so I'm not sure.
  #34   Spotlight this post!
Unread 15-03-2014, 20:22
magnets's Avatar
magnets magnets is offline
Here's a few videos of the problem.
http://www.youtube.com/watch?v=NJ8NMU4aVDs (ball through the goal before it lights up)
http://www.youtube.com/watch?v=IGRYbF7Qll8
http://www.youtube.com/watch?v=cth8G3p6zGk
  #35   Spotlight this post!
Unread 16-03-2014, 19:18
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Still an issue, here is a match from Orlando where you can see the lights don't come on for about 7 seconds.
http://youtu.be/3HqtHBYJLfg
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
  #36   Spotlight this post!
Unread 16-03-2014, 19:32
heuristics heuristics is offline
FRC #3634
heuristics is on a distinguished road
I noticed in this video that the vision targets appear to be switching at the correct times, but the LEDs are clearly way off.
  #37   Spotlight this post!
Unread 16-03-2014, 19:47
magnets's Avatar
Why is this not considered a field fault, and why isn't the match stopped?
If, in the judgment of the Head Referee, an “ARENA fault” occurs that affects the outcome of the MATCH, the MATCH will be replayed.
ARENA faults include broken FIELD elements, power failure to a portion of the FIELD (tripping the circuit breaker in the PLAYER STATION is not considered a power failure), improper activation of the FMS, errors by FIELD personnel, etc.
  #38   Spotlight this post!
Unread 16-03-2014, 20:00
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Also, correct me if I am wrong but I think the blue alliance was scored wrong for Auto, the announcer says they got 40 points but I can't figure how you can get that with 15 in mobility points and either 1 or 2 balls scored (hot or not)
It leaves 25 points scored by balls in high goals, which is impossible.
Edit: I think I figured out what was wrong, the vision targets indicate that both blue balls were scored in hot goals, but the LEDs indicate they were scored in not hot goals. If both blue balls were counted as not hot that would be 30 points. I also think the refs did not notice that 223 moved all the way into their zone before moving back. If only 1065 and 4064 got mobility points for blue that is 15+15+5+5 = 40 points that was announced when it should have been 20+20+5+5+5=55
So 3 problems in the first 10 seconds of the match (if it was even 10 seconds)...
Also, the game announcer audio is also about 2 ahead of the match, as he is correctly predicting everything
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
  #39   Spotlight this post!
Unread 21-03-2014, 07:00
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
After just coming from the VA regionals day one, I was surprised to discover this issue... my bad.
What I don't understand is why the startup logic for the lighted indicator and the dynamic indicator are opposite...
ie: Before auto starts, the LIGHTED indicators both indicate NO hot goal. whereas the dynamic indicators both indicate a HOT goal.
So if you are waiting for a LIGHTED indicator and they come on late, at least you don't take off and score prematurely.
But with the *mechanical* dynamic indicator, any delay in the flip to NOT HOT will cause the robot to take off and score. Adding a "guesstimate" of how long this will take in the code is a realllly bad habit to get into.
It seems to me that both indicators should start in the NOT HOT position, and then transition into HOT mode as required. This would eliminate any false starts.
Phil Malone
http://www.GEARSinc.org
  #40   Spotlight this post!
Unread 22-03-2014, 17:26
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
Orlando's head ref generally refused to accept field faults;
"I don't have time to investigate scoring errors" was what she told us when we confronted her about scoring glitches.
I found 5 hot goal errors in the first 20 matches played:
1. http://www.youtube.com/watch?v=wNWBS...7MSz&index=123
2. http://www.youtube.com/watch?v=ItRyC...9Hg DQxrs7MSz
3. http://www.youtube.com/watch?v=R-hDB...rf9HgDQxrs7MSz
4. http://www.youtube.com/watch?v=shWpl...9Hg DQxrs7MSz
5. http://www.youtube.com/watch?v=DuCft...9Hg DQxrs7MSz
Also why are the hit goal lights coming on during the first few seconds of teleop?
  #41   Spotlight this post!
Unread 23-03-2014, 00:04
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
We noticed this bug in the Virginia Regionals this weekend during the eliminations, and not anticipating the delay cost us a hot goal or two.
  #42   Spotlight this post!
Unread 23-03-2014, 00:58
Nick1912's Avatar
Nick1912 Nick1912 is offline
If ya ain't first ya last
FRC #1912 (Team Combustion)
Team Role: Driver
Nick1912 has a spectacular aura aboutNick1912 has a spectacular aura about
We also noticed the issues with Orlando, but I was hoping from Frank's blog this week where he addressed the issue, this problem would be in the past. I know they will get this working better, everything seems to have improved week to week.
http://www.usfirst.org/roboticsprogr...C-FIRST-Values
1912 Combustion Student 2011-2014
FLL student 2009-2010
FLL Mentor 2010-????
  #43   Spotlight this post!
Unread 23-03-2014, 01:42
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
At Wisconsin we were missing the hot goal when it would light on the side we were on first. The first couple of matches on Friday it was not a problem. Half way through elims we noticed what was actually happening so we added a .5 second delay at the beginning of auto. From then on we never had any problems with it.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
  #44   Spotlight this post!
Unread 23-03-2014, 10:55
chris1592's Avatar
chris1592 chris1592 is offline
Chris
chris1592 is a jewel in the roughchris1592 is a jewel in the roughchris1592 is a jewel in the rough
The reason it appears that the hot goals are still lit in teleop is because the audio/video aren't synced. The audio is slightly ahead of the video.
  #45   Spotlight this post!
Unread 23-03-2014, 11:02
sebas's Avatar
sebas sebas is offline
Sebastian Lopez
FRC #0079 (Krunch)
sebas is an unknown quantity at this point
At the Orlando Regional, our team's auton. would check the Hot Goal about a quarter second after the robot was enabled for auton. During the matches, it would always think there was a hot goal because the vision target hadn't changed yet to indicate that the goal in front of us wasn't hot.
While changes could/will be implemented to compensate for the lag, it'd be nice to have the lag fixed entirely.
