Thread Tools |
Rating:
Display Modes |
Re: New robot rules at Peachtree
I'd ask a very direct question on the Q&A as soon as possible. Individual events should not have additional robot requirements that either supplement or contradict the FRC Manual / Q&A. If this ruling was created in conjunction with the GDC, then it needs to be publicized to all teams through an official form of communication (i.e. A Team Update). |
The question needs to be asked (something like this ... add or update it to make it better): "Does an individual regional, or district event, have the authority to create and enforce additional rules and requirements without these rules and requirements coming from the official FIRST Q&A or Team updates?" |
I suppose this could be interpreted as the LRI clarifying ahead of time how they will interpret/enforce R8.
The reasoning of the LRI may be that all stored energy devices over some undefined quantity of energy (regardless of type) must have lockouts to be considered "safe" per R8. |
Received from the LRI prior to San Diego regional...
In the spirit of R8, Inspectors will be requiring a couple of items if you plan to operate your robot in this manner: 1) Presence of an interlock independent of the firing system that prevents accidental release of the mechanism while in the pit, queuing line, field placement, field removal or any other non-match time the robot mechanism is "armed." 2) Demonstration to the inspector of proper and safe placement and removal of the interlock. 3) A description to the inspector of your plan for safe field removal if the robot is not upright and the mechanism is armed. This interlock does not have to be part of your robot. For many teams a strap sufficed. |
I think that if your team uses a pneumatic system as your firing method, you should be safe of this rule. I'm not entirely sure, but since there is a solenoid going to your cylinders, as long as your cylinders are not compressed (i.e. because of test firing your robot before your match), none, or at least VERY little energy is "stored." I think this rule was mainly aimed at protecting teams using a Tension-Based firing mechanism. I know when my team was prototyping a tension launcher, we called it "The Machine of Death" just because of how dangerous it was to be around it... In a tension based setup, when the firing arm is loaded, all of the energy is stored, but in Pneumatics, generally it isn't.
There's my 2¢. I'm not sure if this is true, but I hope it helps. |
In case no one else mentioned it, this was also a rule at the North Carolina Regional. As far as I know though, it was not enforced, just a suggestion. When my team's robot got inspected we did not show the judges our safety mechanism at all.
#7
I expect FIRST staff and Big Al are already talking about this one. |
#9
Looks like this is not just for Georgia.
#11
There was no such requirement at the Dallas Regional.
However we brought and used a 1 ton load chain to clip our shooter to the frame just in case, and also because it was a good iddea |
#12
None of these "unofficial" updates where conveyed to us before the event. |
#13
Our main breaker was installed about an inch in from our chassis perimeter out of reach of any moving mechanism. We where told to move it within 2 inches of our shooter arms. |
#15
FYI, if you disagree with an inspector, ask to see the LRI, and the copy of the Manual the LRI should have with him. |
