Go to Post Having the foolish belief that you can win a match in which you are completely outgunned will drive you to develop a winning strategy. - OZ_341 [more]
Unread 16-03-2014, 19:39
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
New robot rules at Peachtree
I just received an email blast from the Peachtree regional commmitee. They are now adding a requirement for a "safety interlock", a device that will prevent accidental actuation of a firing system.
In the spirit of R8 and FIRST’s guidance from this update and as a result of other events having experienced accidental deployments of robot mechanisms and injuries while handling robots, Peachtree Inspectors will be requiring a couple of items if you plan to transport or operate your robot in a stored energy configuration :
1) The presence and engagement of a "safety interlock mechanism," independent of the firing system that prevents accidental release of the mechanism while in the pit, queuing line, field placement, field removal or any other non-match time the robot mechanism is "armed."
2) Demonstration to the inspector of effective operation of this interlock and the proper and safe placement and removal of the interlock. This may, at the inspector's discretion, include the demonstration of this interlock device through an attempted "dry fire" of your mechanism.
3) A description to the inspector of your plan for safe field removal if the robot is not upright and the mechanism is armed.
Understanding that this requirement comes after the official Stop Work time for construction of your robot, this interlock does not have to be a permanent part of your robot indeed, the expectation is that it will be removed from the machine when placed on the field, and as such, would not be counted as part of the robot’s official weight, unless significant components are permanently attached to your robot. Inspectors are prepared to be reasonable in accommodating teams’ responses to this requirement - the goal here is safety for all involved.
The Peachtree Committee doesn't want anyone getting hurt while these mechanisms are armed. I trust everyone will see the wisdom of operating this way and compliance will not be a major issue.
I look forward to an exciting Peachtree Regional Competition and to seeing all of you at the event!
The only issue I have here is that since this is not rule put in place by FRC, there is no Q&A, or any other method by which we can get clarification. I have no worries that the launching mechanism on our robot might accidentally fire. I am now worried that we will run into trouble with the inspectors because I do not see an easy way to add an interlock that will not violate the robot rules. Our mechanism is pneumatic in nature, and we must transport the robot with the pneumatic system pre-charged. since the pneumatic rules are very restrictive, most safety interlock systems would violate the pneumatic rules.
There is no governing body I know of to ask questions of, since this was not imposed by FIRST.
This year just keeps getting better.
Former Mentor Team 1771
Former mentor Team 4509
Unread 16-03-2014, 19:46
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: New robot rules at Peachtree
We have a pneumatic firing system as well. We designed a mechanical lockout that does not violate any rules. It is simply a metal bar that goes through 2 eye bolts in the frame. The bar keep the arm from firing even if we hit the trigger while it is in place. We forgot a few times with the practice bot. It makes a dull thud when it's fired with the safety on.
I have had lockouts in all high energy devices after we were told by an inspector to add one in about 5 years ago.
Unread 16-03-2014, 19:47
martin417's Avatar
AKA: Martin Wilson
Unfortunately, our design does not lend itself to a mechanical blocking device.
Unread 16-03-2014, 19:50
JohnFogarty's Avatar
AKA: @doctorfogarty
I'm almost positive that they shouldn't be allowed to enforce this "rule" as much as it makes sense to have such a safety feature.
Glad I won't have to worry about it. My original team might though.
The only way my teams mechanism would accidentally go off in transport from the pit to the field is if we had a catastrophic materials failure from extreme unprecedented stress. Which can be said of pneumatic based systems as well.
However it seems pretty clear to me that all you have to do to not have to add a whole new subsystem onto your robot is not do this.
John Fogarty
Unread 16-03-2014, 19:52
wilsonmw04's Avatar
Coach
a wire with a hook at the end that is attached to the frame?
Unread 16-03-2014, 19:53
Professional Stat Padder
In general, this is a good idea anyway. Both us and our alliance partners (1126) this past weekend had ridiculously powerful shooters. Both also had a mechanical lock in place for carrying the robot in a stored energy configuration. Whether it's just a steel bar through two eyebolts holding back your catapult (20) or a thick metal pin that holds back a powerful slingshot (1126), the stored energy should be somehow contained for a worst-case scenario.
That being said I know exactly what you mean. Can the regional require this since it is not in the official rules? I'm not sure that's okay.
(2015-Present)
Unread 16-03-2014, 19:55
Brandon Holley's Avatar
Ours is simply a loop of high- strength sailing line with a carabiner on it. Loops around the catapult, frame of the robot and back on itself. Giant orange streamer attached to remind us to take it off.
I'm not familiar with your design, but I can't imagine doing something similar is much more difficult for you guys.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 16-03-2014, 19:56
AdamHeard's Avatar
Lead Mentor
would a ball valve inline work for you?
Unread 16-03-2014, 19:57
The only issue I have here is that since this is not rule put in place by FRC, there is no Q&A, or any other method by which we can get clarification.[...]
I suggest asking Q&A, or more to the point, the frcteams email, to clarify if this particular "rule" has its origins at their level, and, in fact, where it originated. If it does not, they will hopefully clarify that. (And ask if you will need to follow it. If they say no, print the message, securely attach it to the robot, and if the event folks refuse to pass your inspection solely on the grounds that you did not comply with this, ask them to contact Al/HQ.)
Rules and rulings that DO NOT come from the GDC DO NOT have to be enforced, and should NOT be enforced.
Note: I don't disagree with the general concept. I HIGHLY disagree with the following: 1) It appears NOT to come from the GDC. 2) It happens AFTER WEEK 3 of competition--way too late. 3) FRC officials are being expected to enforce a rule/ruling that fits item #1 in this list, which is not in any Manual.
Oh, and 4): Only one event? Seriously? If you're gonna apply something like this, it needs to apply to every event after the date of issue, or to no events at all.
Unread 16-03-2014, 19:59
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Martin,
I'd ask a very direct question on the Q&A as soon as possible. Individual events should not have additional robot requirements that either supplement or contradict the FRC Manual / Q&A. If this ruling was created in conjunction with the GDC, then it needs to be publicized to all teams through an official form of communication (i.e. A Team Update).
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 16-03-2014, 20:00
Billfred's Avatar
Billfred Billfred is offline
Small-picture: Ratcheting tow strap looped around? 4901 uses one to fine-tune its release point, but a second one could easily cinch down and prevent firing.
Big-picture: I'm not thrilled with regionals adding "rules" that are not in the competition manual. Many are well-intentioned, but they are infuriating to me as a competitor. (Don't get me started on labeling the main breaker.) Have you tried emailing FRC Team Support?
Unread 16-03-2014, 20:04
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
We figured that we would be asked to have a safety lock on the robot because of the safety rules. (And were worried about moving it without one even though it is very difficult to accidentally release our shooter.) We used a steel shaft through holes on the robot frame, but at least a couple of teams I saw used rope and carabiner or bungee cords. The inspectors at Crossroads were helpful with suggestions.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 16-03-2014, 20:06
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
After looking at the picture of your robot on the blue alliance, I would suggest asking if you could put a removable guard in place of a lock. By guard I mean a tube that would go on the end of the vacuum so even if it was to fire, it would not hit anything. I know this is not the perfect solution but it could be an option (I think).
Unread 16-03-2014, 20:08
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
We had already intended to have a safety interlock on our mechanism; not because the rules or inspectors may require it, but because I would rather not have the robot seriously maim any of our team members. These launchers are dangerous mechanisms.
Here's our simple interlock for a pneumatic launcher: PVC piece that clips over a cylinder rod to keep it in an extended position, so that a dry fire results in no movement.
Unread 16-03-2014, 20:10
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by Karthik View Post
Martin,
^This^
The question needs to be asked (something like this ... add or update it to make it better): "Does an individual regional, or district event, have the authority to create and enforce additional rules and requirements without these rules and requirements coming from the official FIRST Q&A or Team updates?"
___________________
- Tennyson, Ulysses
