Go to Post Band geek FIRST geeks = uberparty! - Nuttyman54 [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 11-03-2014, 20:25
Re: Math Quiz: Parabola Path
Originally Posted by maths222 View Post
As a function of x, it will describe the upper boundary on one side and the lower on the other.
Yes, there will be 2 separate functions - one for the upper boundary and one for the lower (just like Ryan's parametric equations).
It does exist, but it is very ugly. I will try to remember to post it later.
Excellent. Would you please post both a "typeset" version and a "cut-and-paste programming" version? (see example in attachment)
Thank you.
Unread 12-03-2014, 09:49
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
The display ones will come later.
Eq 1:
−11.547344110855*sqrt(((x^(2)+133.34115601449)/(2.*x*sqrt(x^(2)+133.34115601449)*abs(x)+x^(4)+267.68231202898*x^(2)+17779.86388728)))*sign(abs(x)+x*sqrt(x^(2)+133.34115601449))-((0.0433*(abs(x)+x*sqrt(x^(2)+133.34115601449))^(2))/(x^(2)+133.34115601449))
Eq 2:
(((11.547344110855*x*(x^(2)+133.34115601449)-11.547344110855*sqrt(x^(2)+133.34115601449)*abs(x))*sqrt(((1)/(−2.*x*sqrt(x^(2)+133.34115601449)*abs(x)+x^(4)+267.68231202898*x^(2)+17779.86388728))))/(abs(abs(x)-x*sqrt(x^(2)+133.34115601449))))-((0.0433*(abs(x)-x*sqrt(x^(2)+133.34115601449))^(2))/(x^(2)+133.34115601449))
--Jacob
Illinois FTC FTA
Unread 12-03-2014, 12:33
Eq 1:
Eq 2:
Hmm.
Your equations differ from Ryan's by about 0.01 near x=5
Also, the x-intercept of your upper-boundary equation differs from Ryan's by about 0.03
Given the number of decimal places in your equations, I would have expected them to be closer.
Name:	Jacob vs Ryan.png
ID:	16544  Click image for larger version
Name:	Jacob v Ryan (x intercept).png
Unread 13-03-2014, 11:26
Jacob,
Can you re-run Mathematica using the following parametric equations instead?
x_lower = t + 2*a*t / sqrt(1 + (2*a*t)^2);
y_lower = a*t^2 - 1 / sqrt(1 + (2*a*t)^2);
x_upper = t - 2*a*t / sqrt(1 + (2*a*t)^2);
y_upper = a*t^2 + 1 / sqrt(1 + (2*a*t)^2);
Unread 13-03-2014, 19:00
FTC FTA
I used a TI-Nspire and logic to arrive at my equations, so they are probably wrong. I will take a look at them this weekend.
--Jacob
Illinois FTC FTA
Unread 13-03-2014, 20:34
Just to be clear: I am looking for an exact analytical solution, not an approximating function.
Finding a polynomial to fit the numerical parametric functions data is trivial. For example, Here's y=f(x) for the upper boundary:
1-4x2/100
Unread 13-03-2014, 20:53
FTC FTA
I had thought it was exact. I need to think through my logic that I used to develop my equation and figure out what I missed. I had gotten the same parametrics as Ryan; I just have not yet figured out a good way to represent them as a function of x.
--Jacob
Illinois FTC FTA
Unread 16-03-2014, 16:52
Are there any Mathematica gurus out there?
Wondering if there is a solution for the following problem:
Find explicit functions y=y_lower(x) and y=y_upper(x) for the following parametric equations:
Unread 16-03-2014, 21:08
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
I don't have an answer to your new question, Ether, I am about to explain the answer to your first question because none exists on this thread and I'd hate it if I couldn't figure it out and no one explained how they got to the answer. I don't have the paper I figured this on and do not have a decent calculator on me.
This requires an understanding of calculus 1, the normal line.
f(x) = upper curve, y = original curve, and g(x) = lower curve.
Note: f' != g' != y' on [-5,5] except at x = 0.
I realized that f - g != 2 at all x on the interval [-5, 5] except at x = 0, but rather the distance of the normal line from f to g (or vise versa) = 2. I also figured that the normal line +/- a distance of 1 on the normal line of f will get you to f and g.
Given that y = 0.0433x^2, then y' = .0866x. Then the normal line = -1/y'
The normal line of y(x) = -1/(.0866x) = ynorm.
The problem is still find f and g, but this equation gives a line at every point of x that is exactly a unit of 1 away from both f and g.
It will be easier to solve for the x and y components of f and g instead of a function f, which is exactly what ryan did.
With any circle centered at y, where it touches f.x > y.x > g.x and f.y > y.y > g.y, where .x and .y are the x and y components respectively.
so let's make a triangle.
___
The top is change in x (dx) and the left is change in y, dy. The hypotenuse(h) is 1.
So what is the angle between dy and h?
The slope of h = ynorm.
the slope of dy = undefined (straight up).
The slope of dx = 0 (flat).
I do not feel like typing out the equation, the angle between two lines is described here: http://mathforum.org/library/drmath/view/68285.html
and from those equations you get the angle the triangle, which I do not remember the equation for f and g's triangles. I do apologize. From this, you can use dy^2 + dx^2 = 1 (c^2 where c = 1) and simple trig to get a and b for both triangles, and that is the answer.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 16-03-2014, 22:43
Originally Posted by faust1706 View Post
...and that is the answer.
Not sure what you are saying is the answer.
I don't see an explicit function of x anywhere in your post, which is what is being sought.
I'm not convinced such a function even exists. Prove me wrong
Unread 16-03-2014, 22:49
faust1706's Avatar
I post all the remaining work when I find it XD. I am not sure either. I'll work through it more when I have time. I'll ask my calc teacher as well to see if she can come up with an explicit function of x. Quite the interesting problem. Thank you for posting it! I look forward to another one if there will be one.
Unread 16-03-2014, 22:54
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
This is definitely the simpler/faster way to derive the equations, but requires a separate proof that the shortest distance between the original curve and the boundary curve can be found along the normal line of the original curve. For bonus points:
Let y(x) be the original function [ y(x) = 0.0433x2 ]
Suppose f(x) is the equation describing boundary curve that we're trying to find.
Let D(x, x0) = distance between [x, y(x)] and [x0, f(x0)]
D(x, x0) = √((x - x0)2 + (y(x) - f(x0))2)
Do the derivation as the intersection between the hyperplane where the distance between the curves is 1 [ D(x, x0) = 1 ] and the hyperplane where the distance between the curves at the solution points is minimal [ d D(x, x0) / d x0 = 0 ]
FRC 766, 2015-, Mentor
Unread 16-03-2014, 23:01
Curve E is the locus of the center of the osculating circle of the involute of a Curve C in the XY plane. What is the relationship between Curve E and Curve C?
Unread 16-03-2014, 23:05
faust1706's Avatar
I didn't even think about proving that statement. I am a sloppy mathematician. thank you, this was really interesting. Time to read up on "osculating circle of the involute."
Unread 16-03-2014, 23:34
faust1706's Avatar
Are the curves closed?
