Go to Post This special is supposed to promote science, not convert the world to gracious professionalism (though that wouldn't be such a bad idea). - Karibou [more]
Unread 17-03-2014, 12:37
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Destructive Air Tank Testing
*Disclaimer*
Don't try this at home. I have experience in destructive testing and I have a safe location to perform these tests.
Don't construe any results as approved methods for shrapnel mitigation.
Don't construe any results as suggestions for any action.
Don't construe any results as anything other than the results of an experiment.
No students were present during these tests. Experienced adults only.
*/disclaimer*
[EDIT]
Video!
https://www.youtube.com/watch?v=Oea-...ature=youtu.be
[/EDIT]
We are experimentalists here on 95. Given the recent chatter on CD about failing plastic air tanks, and several proposed (or implemented) mitigation techniques, we decided to test some of these solutions. We have a video coming, but I thought I would share our preliminary results.
Most of this year's discussion, and several proposed or implemented solutions, is in this thread: http://www.chiefdelphi.com/forums/sh...d.php?t=127695
Some background information about using plastic to transport compressed gasses from The Plastic Pipe Institute: http://plasticpipe.org/pdf/recommend...ressed_gas.pdf
Safety during a destructive test is paramount, so we did a little research and found this paper detailing the radii for various threats at different amounts of stored energy. On Page 4.7 the thread radii are listed. We calculated that the energy stored in a single plastic storage tank at 120psi was around 370lb*ft of energy. To be safe we used the shrapnel radius for a 500lb*ft radius and gave ourselves a factor of safety of at least 10, and wore eye and hearing protection.
Paper: http://xpda.com/junkmail/junk215/PNNL-18696.pdf
Results summary:
No mitigation - we found shrapnel of appreciable size up to 45ft away lots of small shrapnel pieces, and some larger ones
2-3 layers of Gorilla tape - as some hypothesized the ends of the tank shot out at high velocity, we found one in a snow bank about 25ft away. Virtually all of the small shrapnel was eliminated, but the tank broke into 4 large pieces. However, the larger pieces didn't travel as far, 20-30ft or so.
Bumper fabric zip-tied around the tank - the zip-ties failed almost immediately and the fabric simply un-rolled from around the tank. Shrapnel was slightly mitigated, but large and small pieces were still found 20-30ft away.
Completely Assembled Bumper - we essentially replaced the pool noodles with an air tank. This actually contained virtually all of the shrapnel. It was a completely assembled bumper (3/4in plywood, screwed-in angle aluminum, stapled nylon fabric*). The angle aluminum ripped off of the plywood, and many of the staples failed, but it held together long enough to keep basically all of the shrapnel inside.
*This fabric is considerably stronger than your average bumper fabric. It is heavy-duty nylon, double rip-stop, and impossible to tear by hand along any direction.
Pictures!
Un-mitigated. Not bad for finding white plastic on a snow-covered driveway!
Gorilla Tape
Buper fabric and zip-ties.
Whole bumper.
Unread 17-03-2014, 12:57
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Re: Destructive Air Tank Testing
A thick sock tie-wrapped or wired closed around the pneumatic lines.
Few of those methods (safe for the bumper) would "contain" anything. They merely redirect the energy. You want something that will expand and stretch to absorb the energy while containing the fragments and venting the gases.
When it comes to explosions, trying to contain them rigidly (with tie wraps and tape) rarely works.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 17-03-2014, 13:08
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
Bumper material covers with reinforcements at the ends (double stitching and double material) and pleated material around the main cylinder of the bottle with sparse stitching that will break away, allow the bag to expand and catch the expanding pieces.
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Well, if the sock solution has issues with pieces of tank cutting through it some kind of poly-carbonate mesh could be used.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 17-03-2014, 13:14
foote stepped in
AKA: E. Foote
FRC #0868
Did you have any "before" pictures?
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 17-03-2014, 13:15
Andy A. Andy A. is offline
Getting old
FRC #0095
Just as a quick note: We had a fixed number of tanks to work with and so we tested the mitigation techniques we saw proposed most often and used materials we had on hand.
We would have tested additional containment methods but we sort of 'expended' all our plastic tanks. If anyone wants to send us more we'd be more than happy to do additional testing.
The aforementioned video will go into some depth about the hows and whats of the testing. For now we thought it was worth letting the community know that, at least in our tests, containment of these tanks failed more often then it succeeded, and that it requires substantially more robust solutions than many expect.
Unread 17-03-2014, 13:20
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Here is an air tank ready to test.
Unread 17-03-2014, 13:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What's the diameter on these tanks? I bet something like McMaster p/n 55545K96 would work wonders on containing shrapnel.
Unread 17-03-2014, 13:37
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
I was looking at that stuff too, I was wondering how to cap the ends. Maybe I could stitch it down with some heavy duty nylon string?
I am nervous about the location of my air tanks too.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 17-03-2014, 13:38
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
What method are you using to cause the failure? Simple over-pressurization or are you intentionally over-tightening the end fittings? It would be brittle failure either way, but it may make a difference in how much energy is in the system at the time of failure. An over-tightened fitting would likely fail at a fair lower pressure (eg, potentially below 120psi) whereas a properly assembled tank would not.
On that same note, did you monitor the pressure that the tanks burst at, and if so how consistent was it?
Unread 17-03-2014, 13:40
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Roughly 2.5" looking at the pictures and from first hand recollection
Unread 17-03-2014, 13:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Instead of looking at more wonderful creative ways of containing shrapnel, I'm looking for ways to make sure all of these tanks get replaced with something more reliable at the regionals I attend....
Unread 17-03-2014, 13:55
Head Mentor
I wish clippard made a metal air volume tank the same size as their biggest cylinder. I would love to have a 3" ID tank that is 6" long. hmmm I am gonna email them right now.
Unread 17-03-2014, 13:58
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
At what pressure did the tanks actually fail? I would expect them to have a safety factor of at least 3X.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 17-03-2014, 14:00
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
I would have to agree with you.
These tanks were discontinued for a reason...
I would also like to know how you made them fail?
Threading the fitting in to far or some other method?
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
