Go to Post Build season is the best time of the year. Better than Christmas because the presents are cooler, and better than new years cause you get to stay up later. - burkey_turkey [more]
Unread 17-03-2014, 14:12
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Coding
Your teleop shooter is wrong, it should be like this
if(condition1)
shooter.set(speed)
else if(condition2)
shooter.set(otherspeed)
else
shooter.set(0)
endif
the way you have it up is
if(condition1)
shooter.set(speed)
else
shooter.set(0)
endif
if(condition2)
shooter.set(other)
else
shooter.set(0)
endif
If conditon1 is met, it will still be 0 because the second time around, its setting it to 0
