Go to Post No matter their age, no matter their generation, every mentor and student must be responsible for their actions, and for understand that compromise and maturity are the paths to team success. - Eugenia Gabrielov [more]
  #61   Spotlight this post!
Unread 17-03-2014, 14:11
philso philso is offline
FRC #2587
Re: Let's See Your Robot's Battle Scars
We were competing in Dallas this past weekend and experienced some "contact within our frame perimeter" causing our pneumatic shooter to stop working.
https://plus.google.com/u/0/photos?pid=5991806169142267842&oid=100961862719407 130044
Looking around the pits at the other robots, I saw a bent frame and collector on one of the top robots. Another had a severely bent shooter which was quickly fixed. I later saw that same shooter caught under some frame members that it had no business being under. The team members had to use brute force to flex the shooter and frame to get it back out.
Our driver collided with one of the top robots, knocking the power cable out of their router and stopping them for the rest of the match. One of Spectrum's alliance partners suffered a broken collector but managed to use it to make one last pass to Spectrum for assist points. One of the robots in the semi-finals or finals was dragging an air tank as it drove around the field for a good part of the match. Surprisingly, it did not pop off nor did another robot run over it in all the chaos.
  #62   Spotlight this post!
Unread 17-03-2014, 14:18
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
our ball pick up was actually designed with the purpose of getting hit and bent, we made is so that if its gets bent and warped out of shape they will still work for the rest of the match, and we made them so they are very easy to replace a simple clamp you remove and they slide out, we then produced about 5 of them so that after a match in which it get bent we can replace it with a new one then straighten the bent one as much as possible during some down time so that we can re use it if needed, works absolutely perfect At WPI we replaced the sticks twice during the entire competition, took about 30 seconds to do so.
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
  #63   Spotlight this post!
Unread 17-03-2014, 16:20
Trish Fisher Trish Fisher is offline
FRC #2240 (Brute Force)
Trish Fisher is an unknown quantity at this point
Originally Posted by Sparky3D View Post
Actually, those cylinders are entirely within our bumper zone. But we will be adding some additional protection for them at Wisconsin.
I'm sorry for your damage. How are you going to add protection for them, we have a similar design.
Thanks!
  #64   Spotlight this post!
Unread 17-03-2014, 16:29
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Day 1 at SCH
  • An obliterated camera mount and LED ring
  • 2 ruined drive pulleys (both our fault, 1 touching the cart when testing, the other got Loctite on it a while ago and just failed)
  • Intake roller shaft belt way out of place
  • 4 intake cylinders bent (we actually managed to bend them back in place the 2nd day as we ran out of spares )
Day 2 at SCH
  • 2 more bent intake cylinders, by this point we repositioned them to a more protected spot on the robot.
  • A sheared off Performance wheel (I know, I know, only 3 bolts, we were in a hurry from the loctite pulley )
  • A little something unexpected
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
  #65   Spotlight this post!
Unread 17-03-2014, 16:37
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
1st match of the day in Mt Vernon on Saturday. Our loader got hooked in some manner and failed spectacularly. Had the spare swapped in and running 5 minutes later and we were 100% up and running in time for the next match.
Redundancy and resiliency are critical this year.
We kept the trashed loader as a keepsake
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
  #66   Spotlight this post!
Unread 17-03-2014, 17:06
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
did anything actually break? It looks like everything came apart at the connectors. Were you using PVC cement?
  #67   Spotlight this post!
Unread 17-03-2014, 17:11
AustinH's Avatar
Yeah, everything was glued. There are actually chunks of shattered pipe in those connectors. Normally the passive PVC loader design we used had a ton of extra flexibility. Not this time.
  #68   Spotlight this post!
Unread 17-03-2014, 17:45
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
We have a pinch guard over the drive pulleys of our forward intake motor which, when down, happens to be the outermost point of the robot. We crunched that 1/16 inch aluminum at least once each match, and that's our only real battle scar, unless you want to count a robot cutting through 4 layers of bumper material...
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
  #69   Spotlight this post!
Unread 22-03-2014, 01:30
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Half way through one of our qualifying matches, we found that we were driving with what seemed to be 50% of our normal drivetrain power. Pulled it out after the match to find this.
2 of our wheels were gummed up with field marking tape. One of the kit hex bearings broke as well, I suspect as a result of the immense belt load seen when driving with our clogged pulleys.
  #70   Spotlight this post!
Unread 22-03-2014, 08:00
Ghost_Pack's Avatar
Ghost_Pack Ghost_Pack is offline
AKA: Peter S
FRC #0801 (Horsepower)
Ghost_Pack will become famous soon enough
Can anyone top 801 and 1592's 2013 trailer accident?
http://oi57.tinypic.com/3507wag.jpg
http://oi61.tinypic.com/110eu5i.jpg
  #71   Spotlight this post!
Unread 22-03-2014, 22:51
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Didn't get any pictures but we managed to crack welds on both our primary and backup intakes at the Virginia Regional. Fortunately we were able to get some nice gussets made up by the NASA machine shop and rivet everything back together .
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
  #72   Spotlight this post!
Unread 22-03-2014, 23:16
Best Available Data
FRC #1778 (Chill Out!)
This BAG on a 10:1 VP powers our intake. It spends most of its time inside our frame perimeter or out of the way above our roller claw. After our first QF match (or, at least we noticed it after our first QF match), it looked like this. Much to our surprise it continued working through the remaining QF and SF match ups. Once we can unbag, I can't wait to open it up and see what it looks like on the inside.
Our drivers station overhung our robot cart and got banged by a trophy case in the hall en route to a match. Of course, the laptop screen decided that this would be a great time to go belly up. Luckily, we had our classmate in the pit.
  #73   Spotlight this post!
Unread 22-03-2014, 23:40
Professional Stat Padder
We've had about 10 of these in our drivetrain break.
They're significantly weaker than last year's hex bearings.
We actually ran Finals-3 of Tech Valley with a bearing and a wheel missing. 5 wheel drive instead of 6.
We're in the process of taking the 2013 bearings from last year's practice bot off to put on this year's robot.
Also at Tech Valley, in our first qualification match, our catapult snapped in two a few shots after a bad dryfire in autonomous.
(2015-Present)
  #74   Spotlight this post!
Unread 24-03-2014, 11:13
J@GMFlint's Avatar
J@GMFlint J@GMFlint is offline
FRC #1243 (Dragons)
J@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond repute
Here's the front cross brace from our AM14U chassis during Eliminations at the GLBR District. This year we took a gamble with the KOP chassis for the first time, like many teams we also highly modified it -very little is left "stock" aside from hole patterns- and we actualy found it to be a great product/value. We also found it easy to interface with our staple building material, 80/20, making iterations and repair/replacement relatively easy.
Name:	Front Cross Brace.jpg
14th Season Leading and Mentoring Great Students!!
FINALIST 2014 GLBRD- Thanks 5281 & 2145
Qtr-Finalist 2014 Bedford District
Qtr-Finalist 2014 Kettering District- (Which way was the robot s'posed to be facing...?!)
FINALIST 2011 Kettering District- God work 494 & 1684- great elim. debut Chimera's!
WINNER! 2010 West Michigan District- Awesome job 3357 & 2054!
WINNER! 2004 West Michigan Regional
2004 Rookie All-Star & Highest Rookie Seed Pittsburgh Rgnl; Rookie Inspiration & Highest Rookie Seed West Michigan Rgnl (3rd)
2007 Semi-Finalist MWR
2008 Finalist MWR - Thanks 111 & 1504 Judges Award MWR
2010 Semi-Finalist Kettering District - Thanks 1, & our friends 2337
  #75   Spotlight this post!
Unread 27-03-2014, 00:32
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
We had the same thing happen to us also causing us to miss an autonomous shot one match. I'm sure the field crew always wonders where all that tape goes.
