Go to Post Let gravity be your friend. - MrForbes [more]
Unread 17-03-2014, 13:52
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Team 3309 Presents: Gateway
Reveal Video
Shooter
  • 2-ball/1-hot autonomous
  • Elastic catapult with 2-CIM winch
  • Zone 1, truss shots
Ground Pickup
  • 4-motor piston-actuated
  • Stuck ball protection
  • Low-goal scoring
Drivetrain
  • 2-speed 4-CIM custom 3309 octanum chassis
  • Full encoder support and on-the-fly switching of drive modes
  • 17 ft/s in mecanum mode
  • 4 ft/s in traction wheel mode
See you at the Los Angeles and Las Vegas Regionals!
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 17-03-2014, 14:03
Re: Team 3309 Presents: Gateway
Turned out great, David! You guys are quickly becoming a favorite from California.
Do you have photos of your drive setup?
Also, how robust is that intake arm?
Best of luck!
Unread 17-03-2014, 14:04
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Solid looking robot! Good luck in L.A. and we will see you on the field in Vegas...
2016 Carson W 2122, 2052, 3538, 41, AZ North W 2122, 125, 498, MQA, Idaho F 2122, 3250, 3513, MQA, CCC W 2122, 9122, 6174, ICA
2015 Tesla SF IDA 2122, 3360, 2960, 1311 IRI SF 2338, 2122, 107, 234 UT F 2122, 3230, 3405, EEA, WFFA, AZ West W 2122, 3309, 5059, ICA
2014 Galileo QF 1717, 2122, 3683, 193 UT W 2122, 2996, 3191, ICA, CCC W 1678, 2122, 9073, ICA
2013 CalGames W 2122, 1678, 4171, Judges Award
2012 Newton QF 2122, 610, 488 Spokane W 2122, 1983, 4082, EEA
2011 Newton SF 1730, 2122, 11 IRI F 3138, 16, 2122, 1730, UT W 2122, 399, 3239, MQA, Seattle F 2122, 488, 2850, MQA
2010 Galileo SF 78, 51, 2122 UT W 1696, 2122, 3405, IDA, Sacramento F 2122, 2035, 1834, IDA,
2009 Sacramento F 2144, 692, 115, 2122, MQA
2008 Newton Sacramento W 2122, 1662, 115, CA
2007 PNW Regional Highest Rookie Seed
"Enjoying traveling to more distant events" since 2007
Unread 17-03-2014, 15:49
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
If you have the weight, you may want to consider adding some sort of protection or shielding for those intake deployment cylinders. 1712 has a similar set-up, and we noticed during practice that a direct hit from a flying ball can cause the piston rods to bend. Granted, we're using 3/4" bore cylinders, they're more exposed, and it was first noticed during catching practice (and later repeated during aerial inbounding practice). With your larger bore (1 1/4"??), utlization differences, and more structural elements near the cylinder the risk may be less for you than it was for us. However, we added some aluminum bars above ours to remove the risk of having our intake get stuck in the deployed position because of a bent piston rod.
Unread 17-03-2014, 16:26
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
I think these are 1-1/8", yeah we been slugging balls at the practice bot, so far its been good but we bought 4 more spares just in case. We are running the comp bot with a secondary regulator for these cylinders, 60 psi is overkill.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 17-03-2014, 16:43
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Agreed that 60 psi is overkill. We were running ours at ~30-35PSI, but bumped it up to around 40 psi afterwards to hopefully overcome any slightly bent piston rods we experienced. We borrowed* some spares from 708 when the inital issue occurred, and purchased more afterwards. We also acquired some 1 1/4" bore pistons, but opted not to change to them after we added the shields, since they would end up awfully close to our frame perimeter. We've only experienced one bent piston at competition, and that was the result of user error while attempting to push the buttons on the solenoid (one side deployed while the other didn't, and the bend was easily fixed afterwards).
*Zygmont, note "borrowed"
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
The problem isn't balls, it's other robots. While contact inside the frame perimeter is a technical, that doesn't change the fact that it will probably happen if your robot is as good as it looks and you'll get stuck fixing them.
Seriously, looks like a great robot. I hope I get a chance to see it at Champs.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 17-03-2014, 16:56
Head Mentor
yeah, there is a few other parts that can break too. with the limits of fabricated spare parts, I will have to favor saving the weight for fabricated spare parts. COTS spares on the other hand don't have a limit. I am keeping my spare cylinders in their packaging, I hope to return them if luck is in my favor.
We practice with 3476 a bunch, so far we have been holding up to their ramming speed. We have gotten whacked by their intake a few times. Not sure how we will do in the 6 robot scrum. I do like the 4ft per second tank mode. You should ask code orange about being the receiving end of bulldozer mode
Unread 17-03-2014, 18:21
OZ_341's Avatar Unsung FIRST Hero
OZ_341 OZ_341 is offline
#0341 (Wissahickon)
OZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond repute
Bot looks great!! Good luck at LA and LV.
2010 Championship Chairman's Award
2016 MAR District Champion (thank you 225 & 1257)
2016 Galileo Division, #6 Seed, 9 W - 1 L
2016 MAR District Innovation in Controls Award
2016 Westtown District Finalist (thank you 4954 & 484)
2016 Westtown District Imagery Award (It took 17 yrs)
2016 Hatboro District Judge's Award
Overall Record 49 W - 21 L
Unread 17-03-2014, 18:30
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Looking good! We'll have the great pleasure of competing with, and against you, in both Los Angeles and Las Vegas.
...and maybe an in between scrimmage.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
