Go to Post Of course this should be your decision- not the FIRST community's. Take charge of your destiny. - Wayne C. [more]
Unread 17-03-2014, 17:18
alexander.h's Avatar
alexander.h alexander.h is offline
Lead Programmer, Captain, Driver
FRC #3975 (The Dragons)
alexander.h has a spectacular aura aboutalexander.h has a spectacular aura aboutalexander.h has a spectacular aura about
Exclamation Net Problems!
Hello! We have a net that is used to catch the ball, which dangles around, is 20 cm off the ground and is most likely capable of getting other robots tangled in it. We are planning to put something to cover it up, like fabric or a transparent shower curtain. Our question is if the material we use to cover up the net strings has to be transparent since they might block the drivers' vision if it's not transparent. Thanks!
2012 - Rebound Rumble - Montreal Robotics Festival - Qualified 15th - Semifinalists thanks to 3379 and 3710 (Record : 8-8-1)
2013 - Ultimate Ascent - Montreal Robotics Festival - Qualified 33rd - Dean's List Finalist : Yazid Djenadi (Record : 4-8-0)
2014 - Aerial Assist - Montreal Robotics Festival - Qualified 9th (Record : 6-4-1)
2015 - Recycle Rush *** I predicted the game ***
Unread 17-03-2014, 17:23
nxtmonkeys's Avatar
nxtmonkeys nxtmonkeys is offline
SCP-682
AKA: Parker Wells
FRC #5349 (RoboEagles)
nxtmonkeys will become famous soon enough
Re: Net Problems!
It depends on what the net looks like.
Please post a picture if you can. This will help anyone trying to help you understand what needs to be done in more detail.
Unread 17-03-2014, 17:33
Re: Net Problems!
It's just rope that criss-crosses. We don't have a picture of the robot outside the bag, but we have one of the robot inside it : https://fr-fr.facebook.com/photo.php...type=1&theater
I know you can't see too much in the picture, but that's the best (and only) picture we have of it.
Unread 17-03-2014, 17:57
Tmeziere's Avatar
Tmeziere Tmeziere is offline
AKA: Tim
FRC #3021 (The Agency)
Team Role: Driver
Tmeziere is an unknown quantity at this point
Re: Net Problems!
Our teams robot had a catching mechanism on it that was covered by soccer-net like material. It passed inspection easily. Of course, our drivers knew the rules well and drove carefully, and we received no fouls.
Unread 17-03-2014, 18:09
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
Re: Net Problems!
We used orange barrier netting and never once got tangles, even when someone went inside our frame perimeter, I strongly recommend it.
Unread 17-03-2014, 18:35
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
Re: Net Problems!
Ok, so from what I can see, you would definitely need some sort of clear, highly-flexible material to cover it if you wanted to. I like the shower curtain idea the most. Most curtains are flexible and can stretch some before breaking.
However, many teams use a part once per match. after the match, the part is destroyed. in your case, a clear rain-poncho would also work, and can be bought for a much lower cost than a shower curtain.
See- through is a must if you use a covering.
Tmeziere- Our teams robot had a catching mechanism on it that was covered by soccer-net like material. It passed inspection easily. Of course, our drivers knew the rules well and drove carefully, and we received no fouls.
If you drive carefully, you won't receive fouls and won't have to cover the 'net.'
Hope that I have helped you!
Good luck!
Unread 18-03-2014, 03:06
Keegbot's Avatar
Keegbot Keegbot is offline
AKA: Keegan McCrary
FRC #2438 (Beta Blues)
Keegbot is an unknown quantity at this point
Re: Net Problems!
Last year our robot had a frisbee blocker that would pop up to block shots. We used many different materials, but as the driver, I asked for something transparent in ordert to see and rive better. Being able to see through helped tremendously. When our alliance partner tried to put someting up for defense, they used pool noodles, which made it hard to see and blocked my vision as well as theirs. I'm not sure you need it depending on the height of your robot, but I do suggest you use something transparent.
2012-15: Team 2438 'Iobotics - driver, build team
2016: Team 5975 Beta Blues - college mentor
Unread 18-03-2014, 09:55
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Net Problems!
Team 4301 used a blocker made of smooth cloth that was in no way transparent. It did, however, prove to be stretchy, puncture resistant, and very hard to entangle with. It was also on sale at Hobby Lobby form $4.00 per yard. If you don't mind the bright color, I would recommend the use of this fabric if you can't access anything better within your time restraints.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
