Go to Post She must have known that if she declined the invitation to form an alliance that no one else would be allowed to pick her. (But of course, as any happy husband knows... the wife is always the #1 seed!) - dtengineering [more]
Unread 18-03-2014, 12:22
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Onboard Flashlight
So, I've seen a lot of teams talk about and use flashlights on their robot; I'm curious how teams typically attach, power and activate said flashlights, and what type of flashlights are commonly used.
The most apparent problem I see is how to power the light:
- There are very few small/compact flashlights designed for 12V inputs
- Per R31 you cannot simply power a light via AA batteries
- Per R50 "The only power regulating devices for actuators permitted on the ROBOT include: ..." this would seemingly disallow the use of a 12V-5V power supply; R51 goes on to show that Custom Circuits are included in R50.
- Powering directly from some 5V source on the Digital Sidecar seems like it could consume more power than would be desirable.
Are there specific flashlights that lend themselves to FRC applications (i.e. 12VDC and mechanical switching)?
Otherwise, am I reading too much into the rules, or ignoring an obvious solution?
Unread 18-03-2014, 12:31
Re: Onboard Flashlight
A flashlight is not an actuator.
Unread 18-03-2014, 12:33
404'd's Avatar
404'd 404'd is offline
Lead contributor of sweg
AKA: Josh
FRC #0967 (Iron Lions (9-sits-7))
404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all
^ What Mark said. R50 only applies to Motors/Actuators defined in R29
Driving "Career":
2012 GKC: Quarterfinals w/ 6th seeded alliance | Wisconsin: Quarterfinals - 3rd seeded alliance captains
2013 GKC: Quarterfinals w/ 5th seeded alliance | North Star: Regional winners, 2nd seeded alliance captains
2013 CMP: Curie Semis w/ 2056 + 3990
Unread 18-03-2014, 12:36
coalhot's Avatar
coalhot coalhot is offline
Assistant to the regional manager
AKA: Phil
FRC #4454 (Artisan Rockets)
coalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant future
Send a message via AIM to coalhot
I would probably find a flashlight that runs on 12v, preferably a LED one, and wire it up to a spike for control. Quite simple...
Current home, 4454 (Glowa's ghetto Philly FRC team). Check us out!
My posts represent my personal views only, and do not represent the views of my team, its school, sponsors, or FIRST.
Unread 18-03-2014, 13:18
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
If you want to control when your flashlight turns on and off, this is the simplest way to do it. Attach the flashlight to a Spike relay, and control the spike using the relay pins on the digital sidecar. Alternatively, if you want the light to be on at all times, you can attach the light to the PDB for 12 volts, or one of the 5 volt GPIO ports on the digital sidecar (red is +5v, black is ground).
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 18-03-2014, 13:39
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Per Q&A #350, you are allowed to use additional 12V > 5V Converters on the robot for powering custom circuits:
Originally Posted by FRC Q&A #350
Q. In response to our previous question, can we use an additional 12VDC-to-5VDC converter for a custom circuit on one of the 30 amp load terminals on the Power Distrobution Board?
A. There are no rules prohibiting this.
The 5V Converter should allow you to use a bunch of different COTS flashlights without too much trouble, although the light output may vary a bit depending on what the flashlight is intended to be run on, and you could have issues with shortened life span if 5V is significantly higher or lower than what is ideal.
That being said, if you're just looking for a reasonably bright light that will work with the robot without too much hassle, you can very easily find a 'Driving Light' or 'Work Light' made to be used with Automotive 12V Systems. Power this through a Spike Relay and you've got an easy light with on/off control.
-Dustin Benedict
Unread 18-03-2014, 13:46
M. Lillis's Avatar
M. Lillis M. Lillis is offline
AKA: Michael Lillis
FRC #0177 (Bobcat Robotics)
M. Lillis has a spectacular aura aboutM. Lillis has a spectacular aura about
The only posts by 180 about their light say that it is an LED mag light. Does anyone have any specifics on the model number or have better suggestions?
Driver 2012-2014
Official Record: 82-44-0 (1.86 W/L)
2014 Elimination Record: 18-2
2014 CT State Championship Winner
2014 New England District Championship Winner
2014 Hartford District Winner
2014 Granite State District Winner
2013 CT State Championship Winner
2013 Connecticut Semi-Finalist
2012 Connecticut Semi-Finalist
www.BobcatRobotics.org
Unread 18-03-2014, 14:09
Mastonevich's Avatar
Mastonevich Mastonevich is offline
Andrew
AKA: Andrew Elsen
FRC #1987 (BroncoBots)
Mastonevich is a jewel in the roughMastonevich is a jewel in the roughMastonevich is a jewel in the rough
Last year we bought a bright outdoor flashlight from BassPro. It had the capability to remove just the head.
We encased it in a tube to contain the side light as much as possible. We used a 12v-5v converter and ran the 6volt light on 5 volts. We used a spike so we could turn it on only while aiming.
It worked well.
(Sorry I don't have the model number)
~Andrew
Regional Chairman's: 2013-Alamo, 2010-Oklahoma, 2009-Colorado
Engineering Inspiration: 2016-Hub City, 2012-St. Louis, 2008-Minnesota
Regional Wins: 2010-Oklahoma
Unread 18-03-2014, 14:13
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Technically, you could power an actuator with a light source. Of course, that's not the intent of the rules.
Unread 18-03-2014, 14:26
Programming Mentor
AKA: Joe S
After doing some additional searching, I found these:
https://www.superbrightleds.com/chec...46ddc923a8ef3d
They are automotive brake/turn lights, and a socket for easy mounting, and have a narrow beam angle.
Searching for 12v flashlight, worklight, etc yields primarily rechargeable lights, which wouldn't necessarily operate at their charging voltage.
Thanks for the correction on R50.
I'm still curious what other solutions other teams use, if they are willing to share. Knowing what you need is typically much easier than finding what you need.
Unread 18-03-2014, 15:46
Jim Zondag's Avatar
Jim Zondag Jim Zondag is offline
Team Leader
FRC #0033 (Killer Bees)
Jim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond repute
We used this:
http://www.amazon.com/DEWALT-DCL0900...led+flashlight
These are great for this application because they are current controlled and thus will run on almost any voltage. They are very bright, very light, tightly focused, and are only about 2" deep.
"To learn what is possible, we must attempt the impossible." Arthur C. Clarke
Unread 18-03-2014, 16:07
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
We just hooked it up to the PDB through a few 7801 voltage regulators. We ended up not using it for competition because the light that we had selected was perfect for our vision code people (it was even the right shade of green!), but was not focused enough for manual targeting. (Sorry, I don't have a product number, but it was originally intended to be mounted on a gun or something.)
We should have ran it through a spike relay, but did not have the time. I will also say that even running our light through two 1-amp 7805s run in parallel with a heatsink was not enough to power the light for more than a minute or so without getting scary hot.
Unread 18-03-2014, 16:21
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Originally Posted by Jim Zondag View Post
We used this:
Thanks for the example! I'm debating using this for aiming ourselves.
All opinions are my own.
