Go to Post Is there a way to spotlight an entire thread? - ctt956 [more]
Unread 19-03-2014, 00:54
Coachthayer Coachthayer is offline
FRC #5318
Coachthayer is an unknown quantity at this point
Window motor in autonomous
We are using a window motor for our ball collector and it works great. However, I can't seem to figure out how to turn it on and off during autonomous. I would also like to be able to reverse the direction. I'm a new LabView programmer so please keep it as simple as possible. Any help would be appreciated.
Unread 19-03-2014, 01:02
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
Re: Window motor in autonomous
Are using globals to set your motor speeds or just setting it with motor Set in autonomous? With the motor Set vi, you can input constants for the motor speed ranging from -1 to 1, -1 being backwards, 0 being stopped and 1 being forwards. If you put this motorSet into a loop in periodic tasks running about 50ms, you can write to a global value in autonomous, then read the value and set the motor in periodic tasks. This method helps resolve many errors and many headaches. XD
Per Audacia Ad Astra
