Go to Post Past success does not guarantee future results.... - Koko Ed [more]
Unread 19-03-2014, 04:24
Wazzaps Wazzaps is offline
FRC #1573
Wazzaps is an unknown quantity at this point
Exclamation Problems when switching to java from labview
We decided we will switch to java from labview but when we wrote an example program and tried to put it on the robot, Nothing worked (sidecar showed 1-4 relay ports on for some reason) Yes, we formatted, we tried in safemode also. It is an 8 slot CRIO-I. We tried switching cables between the CRIO and the sidecar, nothing worked. Help?
Unread 19-03-2014, 07:41
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Problems when switching to java from labview
What was the program supposed to do? Can you post the code?
Unread 19-03-2014, 15:27
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Post your code
