Go to Post P.S. While I doubt Karthik's "Delgado" jersey would go for $500,000... it would be much cooler to see Carlos Degado wearing a "Kanagasabapathy" jersey. THAT I might pay for! - dtengineering [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 19-03-2014, 08:36
bbradf44's Avatar
bbradf44 bbradf44 is offline
AKA: Brad
FRC #3344 (Robocopz)
Team Role: Driver
bbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nice
Re: HTMLish based scouting
Here is a test google form i put together https://docs.google.com/forms/d/1fCb...DVMhM/viewform if people can fill out the form with test data that would be great. Because it is just test data if you could keep the "match number" field to any number under 20 and for "team number" keep it any number under 1000 all other fields just keep realistic(no ones going to be scoring 9999999 points in a match). If you have any suggestions/criticisms/things i should add please put them in the "notes" section
Unread 19-03-2014, 09:43
jlmcmchl jlmcmchl is offline
FF - The Breakfast Company
AKA: Jordan McMichael
FRC #0027 (Team RUSH 27)
jlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud of
How should I be judging the coordinates fields, and "Points Made"? I've seen teams score way more than 10 points, and there is not enough information to make a good judgement on coordinates (relative to where, what unit to use).
Field reset: Kettering Kickoff ('13, '14), Kettering ('14, '15), Bedford ('14), Woodhaven ('16), Carver ('16), Einstein! ('16)
Referee: Bedford ('15), MARC ('15, '16), Kettering Kickoff ('15, '16), Kettering District (#1&2: '16), Troy ('16)
Unread 19-03-2014, 11:01
bbradf44's Avatar
AKA: Brad
Team Role: Driver
the scouts up in the stands will have a gridded off picture of the playing field. i would want to know where on the field the robot shot from the most. I will probably get rid of the "points made" field. originally it was going to say how many total points the team made excluding assists. I may change it to ask what their total contribution to the alliance was as far as points(1 high goal, 1 assist, and 1 truss shot would be 10+10+5=25)
Unread 19-03-2014, 14:35
On the form, "Points Made" said 0-10, so I was confused.
Actually, 1 assist is worth 0 pts/robot. 2 is worth 5 pts/robot, and 3 is worth 10 pts/robot. You'll want to consider this.
Unread 19-03-2014, 14:49
bbradf44's Avatar
AKA: Brad
Team Role: Driver
Fixed. I took that field out
2011: FRC 1922 Team Member
2012 (Build weeks 1-3): FRC 1922 Team Member
2012 (Weeks 4-Competition): FRC 3344 Mechanic and Pit Crew
2013: FRC 3344 Mechanical Lead and Head Driver
2014: FRC 3344 Team Captain and Head Driver
Record as driver: 7-11-0 and Proud of it
Unread 20-03-2014, 11:01
bbradf44's Avatar
AKA: Brad
Team Role: Driver
heres the new link: https://docs.google.com/forms/d/1fCb...DVMhM/viewform not sure if the old one still works
[IMG] code is Off
