Go to Post Chief delphi is a great way to communicate ideas, meet people, and gain knowledge is multiple fields. - Tyler Olds [more]
Unread 19-03-2014, 10:06
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
Re: Possible FMS problems.
Canon,
The issue you describe is usually attributed to one or more of the following problems in no particular order.
1. The cRio is bumping into robot frame or is attached to robot frame electrically.
2. Wire whisker is touching the opposite polarity on the power supply wiring at either the cRio end or the PD end.
3. Power wiring is not inserted into the connector properly, a tug on the wiring will show this problem.
4. Rare manufacturing defects have been observed on the main breaker. while the robot is thruned on and booted, trying lightly tapping the red reset button on the breaker. If the lights on the robot blink, replace the main breaker.
Yesterday we tested for all of these, we replaced all the connectors from the CRIO to the PD board, we tried shaking the CRIO to get it to reboot, we also tried the tapping on the reset, and pulling on the wires. I think what we will have to do next is test the PD board connections to the motor controllers and all of the breakers. We also put in two new vector motor controllers this week and our mentor also had us wire the fans to a 30 amp slot on the PD board.
