Go to Post Age should not be a speed bump to creativity. - Greg Needel [more]
Unread 19-03-2014, 19:03
Blackout Blackout is offline
Programmer
AKA: Trey
FRC #2130 (Alpha +)
Blackout is an unknown quantity at this point
Axis Camera Frames Freeze in Roborealm
For a couple seconds to several minutes the camera works fine, but then the stream seizes up and the frame count stops.
The live stream from the web application (10.xx.yy.11) in a browser streams fine for what seems like indefinitely.. As it should.
- We are connected to the camera via Ethernet. We aren't connected to anything else at the same time.
- Only freezes in RoboRealm.
- Will start back up after reconnecting the Ethernet cable.
I've updated RoboRealm to the latest version and it persists.
What do you guys think?
