Tags
Where do we get more tags for the bags?
Re: Tags
http://www.americancasting.com/info-...ls-9001-16.asp
Also from manual: Quote:
Re: Tags
As per the 2014 "Where to Get More" document, http://www.americancasting.com/.
[ edit ] whoops - Mark's got you covered. |
Re: Tags
If you are at an event, then you can get them from spare parts also.
Re: Tags
Q392 says "there is no requirement that the specific tags from the KOP be used." This implies that any serial numbered zip-tie/seal/equipment tag that functions similarly to the KOP tag is acceptable.
