Go to Post Crushing the box makes it much easier to think outside the box. :D - Matt C [more]
Unread 19-03-2014, 23:20
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Find Encoder Value in Teleop
To speed up our shooter aiming, we are incorporating an encoder on the tilt axle to automatically find the angle of the mechanism (and through logic adjust the shooter up or down as necessary). We have successfully found the output, and "transformed" it mathematically into an angular reading, but we can't access the value in our teleop program (where we need it) only in the periodic tasks program. Help!
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 19-03-2014, 23:24
Re: Find Encoder Value in Teleop
What's keeping you from reading the encoder output in Teleop?
Unread 19-03-2014, 23:43
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
I'm not the programmer - but I think if they knew that, they would have solved it. We have the encoder (AS 5030) plugged in to the first input of the analog breakout...we can read it on the dashboard, and access it in periodic tasks, but not teleop (and I assume not in autonomous, where we will also need it).
Unread 20-03-2014, 06:02
I suspect that the periodic is not only reading the encoder, but controlling the elevation. One approach is to share the calculated value, via a global variable. The RobotGlobal is a reasonable place to put a named numeric for this purpose.
An alternative is to call a shared subVI that reads the encoder refnum by name, reads the raw value, and calculates the angle. The subVI would be shared by Periodic, auto, tele, or wherever.
Greg McKaskle
Unread 20-03-2014, 16:33
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Greg McKaskle
Thanks - Programmers are experimenting and believe this (global variable) is the answer. You're a life saver!!!
