Go to Post it is not as hard as it looks, but thats prolly cause we havent tried to build it yet... - robolemur1236 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 14-03-2014, 00:51
Best Available Data
FRC #1778 (Chill Out!)
Re: Kitbots after Week 1
We have yet to compete, but with our fully loaded robot (110-120 lbs with bumpers & batteries) we get some bouncing on very tight radius turns with the 1/2 wide 1/2 long square AM14U configuration. Not a big problem, but a minor annoyance. I suspect the critical point is somewhere north of 100 pounds, as we never noticed it until after the bumpers went on.
Unread 14-03-2014, 07:56
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
My team 1108 used the kit frame to win the Crossroads regional. We have stock wheels and stock gear-boxes but with up-ratio gears. We're about 28" square.
We've seen extensive wear on the wheel treads, but they don't seem to grip all that much less. Weighing 95 lbs, we're still able to push most robots, especially sideways. Across the front, we have an exposed section of the extrusion where we took a significant hit and bent it in about two inches. We bashed it back out and bolted a piece of steel bar-stock below the angle and it was okay through the finals.
With a slightly light robot, four CIMS and up-ratio gears, we've measured 110 lbs of pulling force and about 12 ft/sec. Great acceleration too. I think these numbers make you competitive in most arenas. We'll see how that works out for the Championships.
I think its' easier to build a robot on than the c-frame was, but on the downside, it takes away one more area to be creative from the kids. But we're a small team and saving the resources for the rest of the design was beneficial to us. It's also a change mounting bumpers to.
Unread 14-03-2014, 08:43
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by IKE View Post
I was LRI at Southfield this weekend and saw a lot of kit-bot and improved kit-bots that faired very well. The architecture of the kit-bot was basically state of the art chassis for 2006-2008 if you just add in a set of shifters. A lot of great robots played really well with significantly less.
Structural bellypans are a great add on. Probably even above shifters. While it doesn't need to be made out of 1/4" steel, a good belly pan attached with rigid connection (not zip ties). If you have ever built a cheap set of shelves, the carboard panel for the back is more important than looks. It adds a ton to the structural rigidity of the shelves.
Ike, what you consider state-of-the-art right now?
Unread 14-03-2014, 08:52
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
The kitbot with a nicely mounted set of bumpers will take and yes give hits as it comes out of the box.
Add good solid belly pans is the best place to start. We used 1/4 inch plywood.
But don't do what one of drivers did was to lose control in the school hallway and crash at full speed into a brick wall without the bumpers installed. That took a hour of body work to get the bent frame straighten out.
Unread 16-03-2014, 01:53
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
Figured I would give an update...
We are all very, very pleased with the resiliency of a properly reinforced AM14U kit chassis. Between PNW Glacier Peak and PNW Mount Vernon, we took hits strong enough to shear at least three 5/16 bolts holding our upper mechanisms onto our frame. The frame is still in great condition. Kudos to the designers for coming up with the kitbot design.
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
Unread 20-03-2014, 07:10
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
So our 3/4" plywood belly pan, and the 1/2" Alum. bar stock (real bumpers beneath bumpers), actually we needed to extend the frame a half inch in front to get a chain sprocket for the collector just inside the frame perimeter on 1 end, and something much stronger on the other to mount the launching catapult upright to, so we spanned the inside frame rails w/ 1/2" stock there, and built a tank to protect the other tanks inside, (add a blade and eyes on the front, instead of tusks....(or is that the rear?)....it would remind you of lil' Blue "Dozer"), across both front and rear of the kit bot frame should fare OK this weekend? (Who said it should be a really low center of gravity game this year anyway? We did!)
It made us switch from chain and sprocket, to belt and pully for the very 1st time ever. Hope it was the right move.
Unread 20-03-2014, 07:42
Tungrus Tungrus is offline
Tungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the rough
At Southfield - MI week 1 competition kitbots did well, beyond our expectation. At one point we wished we had opted for kitbot, it would have saved lot of our time.
Unread 20-03-2014, 13:50
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
No shame in the kit box at all as a starting point.
STARTING POINT.
Have fun with it augment it to play the way you want modify it to drive the way you want, the reason why its sold is because its viable. Flat field, no obstacles, driving isn't all about machine there is skill involved. I've seen robots that are well equipped have drivers that obviously had no idea how to put up with mecanum robots.
Unread 20-03-2014, 13:53
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Team 2950 played a really strong defense and even defended two bots at once from getting the ball. Defense was really nice with the AM14U. We run VEX DT wheels with a wide base frame. With our own electronics board.
