Go to Post Titanium is almost twice as heavy as aluminum. I can have the bragging aspect of making a bullet resistant robot, but if someone is coming into a competition and shooting my robot, I have more important things to worry about! - Andrew Blair [more]
Unread 20-03-2014, 22:44
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
Pistons not extending fast enough?
Hello. Today we conducted a test for a pneumatic system which we are looking to add to the robot before the next competition, but we were met with a rather unsuccessful attempt at shooting a ball. I'm posting here to hopefully get some suggestions to improve the design and/or point out any fundamental flaws with the system.
The tanks were charged at around 90 PSI (the working end pressure guage was displaying about 70 PSI, this needs to be reduced). The setup was constructed sort of arbitrarily, in that I didn't make any exact measurements to emulate the robot in any particular way. This was set up more as a proof of concept, and unfortunately, the proof of concept seems to have failed.
Differences from the design that'll go on the robot (see pictures):
1. When fully retracted the pistons are attached so that the ramp is upright; this is opposite of what the actual design is at the moment, whereby the pistons will be attached so that the ramp will extend from about its current 30 degrees below horizontal to approximately 45 degrees above horizontal (or as close as possible, that being the idea angle for kinematics. This could certainly change if/when I get around to reading some of the more complex analysis that has been done on the physics of the ball). To account for this, we angled the setup (as demonstrated in the videos), though I'm not sure how closely we replicated the movement.
2. The ramp we're using is made of wood and lacks the metal side rails that are on the ramp currently. This would have made it easier to launch the ball as it is significantly lighter.
3. The hinges are strap hinges instead of piano hinges as are currently supporting the ramp on the robot, though I doubt that matters much.
4. We were shooting at a PSI that was slightly higher than the allowed 60 PSI (70); at least, that's what our guage read.
That being said, I think that this test should have at least proved to some degree whether the concept would work. However, after doing it, I found that the ramp rotates much too slowly to be able to do anything productive; notice that even the light basketball from two years ago (rebound rumble) hardly launched off the board.
Would attaching the pistons at the very bottom of the board make that much more effective that it can launch a ball across the room? It also seems as though the pistons are extending much too slowly; is there anything we can do to fix this?
Piston setup:
Robot Ramp (in bag):
Walkthrough of testing setup:
https://www.dropbox.com/sh/eob698yuo...kthrough.mp 4
Test 1:
https://www.dropbox.com/sh/eob698yuo...320_175538.mp4
Test 2:
https://www.dropbox.com/sh/eob698yuo...320_175720.mp4
Test 3:
https://www.dropbox.com/sh/eob698yuo...320_175801.mp4
Unread 20-03-2014, 22:48
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Re: Pistons not extending fast enough?
Sorry, a better question is what's the PSI on the regulator?
College sux yo
Unread 20-03-2014, 23:07
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
A single solenoid will not give you enough airflow to extend with enough force to launch the ball. What you need is a way to help the piston along. I have seen two different ways to do this.
1. I haven't done this, but I have read about it. You can add a spring to the arm of the piston so that it extends outward more quickly.
2. The second way is how my team did it. You pull the piston in and have it lock in somehow(we use a gate latch). You then push the piston outward. The piston tries to extend but can't because it is locked in. Then when the lock is released, the piston releases with more energy because you have pre-pressurized the piston. (The one problem is that our catapult system requires two huge pistons. These two pistons take a lot of air and therefore require several tanks.)
I hope this helps but it might be hard to implement on your robot because it has already been mostly built.
Unread 20-03-2014, 23:09
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
You will get much better results using smaller diameter cylinders. Those large ones in the picture require too large a volume of air to fill, thus the extension speed is not fast. Use much smaller cylinders (same length, smaller diameter) for a fast launch.
You may also wish to look at the flow rate on your solenoids. We are using a new solenoid we bought that has a much higher flow rate than the solenoids that were FRC legal last year and before. No flow rate restriction this year - only limit is port size.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 20-03-2014, 23:10
ttldomination's Avatar
Sunny
So, I have a basic understanding of pneumatics, so I'll attempt to advise you the best I can. Warning, this is going to be a long read, so take a deep breath, and try to understand as much as you can.
The name of the game is flow rate. How do you move air as quickly as possible into the cylinders? If you move the air in quicker, the cylinder will shoot out faster.
Before I get into this, I'm going to set up an analogy for us to follow. Think of the cylinders as buckets, and the solenoids as hoses that carry water. The goal is to fill up the buckets of water as fast as you can.
Now, based on the videos, you have one solenoid hooked up to two, fairly large, cylinders. You're essentially trying to fill two big buckets with one hose. So, how do you make the system faster? How can you change up your variables (buckets and hoses) to make the system fill up faster?
Let's go through a few scenarios:
Use more hoses - Of course, if you use, say, one more hose (read: solenoid), that'll help with the flow rate, and it'll help you fire quicker. Now, I believe the rules limit you to maximum one solenoid per cylinder, so keep that in mind.
Use smaller buckets - While this may seem counter intuitive, this is also correct. Using smaller cylinders will help you fire faster. There's a tipping point between cylinder size that gets you the best speed vs. power. I'd recommend reaching out to a team to find out what they're using.
Use a larger hose - Now, this is interesting. If you use a solenoid that's rate for a faster flow rate, you can move air quicker, which will ultimately shoot the pistons out faster. FIRST doesn't impose a solenoid flow rate limit, but given a set of constraints (price, power, etc.) you may be limited on what's actually available to you.
Pool your water into a smaller bucket ahead of time - Now, this is a little bit more difficult to understand, but bare with me. Let's say you pop the solenoid and let the cylinders build pressure, but you lock down the shooter. Then, at a later point in time, you manually release the shooter (via a latch or something). Here, the cylinders are essentially acting like compression springs, but you are able to get over the flow rate problem.
That's the tip of the iceberg, and I recommend you do some more soul searching (read: researching) into your issues, your system, and which solutions would best fit your setup.
Here are some other threads that may help:
Team 842's Amazing Machine
Creating Pneumatic Launchers
This talks more about letting the solenoids fire before you release the catapult.
Let me know if this makes sense, if there are any errors, or if you need any further assistance/clarifications.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 20-03-2014, 23:21
azcalg's Avatar
azcalg azcalg is offline
FRC #1212 (Sentinels)
azcalg is a jewel in the roughazcalg is a jewel in the roughazcalg is a jewel in the roughazcalg is a jewel in the rough
As mentioned, you should really be using a solenoid for each piston, we found that attaching them directly to the shooter worked better. Additionally, you may want to move your pistons farther towards the pivot point and start the catapult at a lower position. It sounds like a weird thing to do but when the catapult requires a greater amount of force to move initially it causes the air to build up in the piston first, basically doing the latch thing without an additional mechanism. Here's a video from our first prototype, we currently have two pistons that I believe are the same size that you guys are using. You may also want to check out 842's design, they have a great pneumatic shooter.
Unread 20-03-2014, 23:25
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
This might give you some ideas, and it's the clearest picture I have of our shooter which appears to be similar in geometry to what you are attempting to accomplish. The pistons are 7" stroke, both have a small air tank on the working pressure side attached to each piston. The pistons push just short of over center (they almost line up with the hinge point on the front of the "catapult"). This puts only a slight force on the modified gate latch(not seen on the left side of the picture inside the robot, actuated by a .5" stroke piston which lets go to release the pre-pressurized shooter. The pivot is a pair of door hinges and there is a strap to prevent the pistons from smacking into the end of the cylinders whey they extend.
https://www.youtube.com/watch?v=rbYT...m-upload_owner
Unread 20-03-2014, 23:31
I'm not quite sure I understand what you mean, but I can tell you that for each of the tests the pressure gauge on the high pressure side (before regulator) read about 90 PSI and the pressure gauge after the regulator was at a solid 70ish PSI.
Unread 20-03-2014, 23:35
Lord of Lazy
Okay so I was reading that correctly. If you are using a single noid for both of the pistons, switch to 2 of them for each, like others have already said. Better flow rate means faster extension.
College sux yo
Unread 20-03-2014, 23:41
There isn't actually a solenoid in the testing setup, but I do see your point with the airflow problem. Would I be able to improve this by adding two small tanks on the working side and pressurizing them to 60 PSI, plumbing each tank to its own cylinder?
As for the latch system, it seems that many teams are doing that this year. We may have to end up doing something similar, perhaps with a small stroke piston (or a rotational cylinder we have lying around?), though I would like to avoid this option as it may be at the edge of our capability technically.
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
In addition to what everyone else has said, be sure that you test with 60 psi working pressure as mandated in the rules. Also, I suggest that you include a hard stop before the piston reaches the end-cap of the cylinder to prevent damage to the cylinder.
P.S.
Piston is the thing that moves, while cylinder is the entire actuator.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 20-03-2014, 23:44
Could you perhaps provide a link or a google search directing me to solenoids similar to those you're using? Currently we've got some solenoids left over from the early 2000s, and I'm not sure what teams are using now.
As for the cylinders; if the diameter becomes too small, wouldn't they not have enough force to push the ball + platform? I will do some calculations and figure out how much force would be needed from each piston to move the ball however, and will certainly see what the smallest piston we can use is.
Unread 20-03-2014, 23:46
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
FYI, R90 prohibits plumbing to solenoids two one cylinder.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 20-03-2014, 23:51
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Originally Posted by MrBasse View Post
FYI, R90 prohibits plumbing to solenoids to one cylinder.
I believe what is occurring is that one solenoid is currently connected to both cylinders, and he was recommending to use one solenoid per cylinder for a total of two in the entire assembly.
KK4KQO
http://voltair.us
Unread 20-03-2014, 23:53
It's good to be sure... Some would overlook that and see that a higher flow rate copied be a how'd by running two together. Better at this point to keep everyone well informed to save hassles at competition.
Andrew Basse
