Go to Post Keep in mind that the lady Amanda has just taken a new job, moved herself to the NorthEast, and has to put up with people like Grady, Needel, the Kelsos, and Boucher. Let's give her some patience and sympathy. - Andy Baker [more]
Unread 20-03-2014, 23:55
Answer42's Avatar
Answer42 Answer42 is offline
Answer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud of
Re: Best Inbounder Qualities?
Originally Posted by JohnFogarty View Post
Were using an AndyMark 6CIM Single Speed gearbox powered kitbot.
We're considering switching to Colsons for World gathering that we can modify the wheels to work with the belt hubs. If not, we'll have several sets of the high-grip 4" wheels for championship.
We actually won Orlando using the exact strategy you mentioned. So that makes me feel good that someone else considers this strategy of play to be an effective inbounder skillset.
It's fantastic that you guys are happy to play that role.
As far as mounting colsons with the kitbot. This document:
http://content.vexrobotics.com/vexpr...ive-System.pdf
Explains how you could replace the KOP wheels with vex pro wheels and pulleys. Since they use the versahub mounting pattern, I assume you could swap in http://www.wcproducts.net/colson-hub/ in place of the versawheels, to mount your colson wheels onto. Good luck with your preparations.
My comments do not reflect the views of associated teams.
