Go to Post Keep arrogant, belittling and misspelled bragging off these boards. - Mike [more]
Unread 20-03-2014, 23:55
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: Pistons not extending fast enough?
Originally Posted by MrBasse View Post
It's good to be sure... Some would overlook that and see that a higher flow rate copied be a how'd by running two together. Better at this point to keep everyone well informed to save hassles at competition.
Agreed, I would not want to spend precious time between competitions tuning a system only to arrive at an event and find its illegal.
KK4KQO
http://voltair.us
Unread 20-03-2014, 23:57
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
Originally Posted by ttldomination View Post
[Lovely explanation]
Thanks so much for the great explanation, it really helps understand the whole concept of airflow. Apart from changing from one solenoid to one per cylinder and adding a higher airflow solenoid (if possible), would there be anything else I could do to increase my airflow?
Unread 21-03-2014, 00:00
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
The pressure regulator also restricts flow rate somewhat. To compensate, you could add additional accumulator tanks on the low pressure side of the regulator.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Originally Posted by azcalg View Post
As mentioned, you should really be using a solenoid for each piston, we found that attaching them directly to the shooter worked better. Additionally, you may want to move your pistons farther towards the pivot point and start the catapult at a lower position. It sounds like a weird thing to do but when the catapult requires a greater amount of force to move initially it causes the air to build up in the piston first, basically doing the latch thing without an additional mechanism. Here's a video from our first prototype, we currently have two pistons that I believe are the same size that you guys are using. You may also want to check out 842's design, they have a great pneumatic shooter.
What do you mean by directly attaching them to the shooter?
I will be working on modifying the catapult so that it starts in a lower position and the pistons are closer to the hinge point. I'm also going look into 842's design a bit more, thank you for pointing that out. It seems they're using the same size pistons as us; if they are having no issues shooting, maybe we'll be able to do the same.
Unread 21-03-2014, 00:03
Originally Posted by Matt C View Post
This might give you some ideas, and it's the clearest picture I have of our shooter which appears to be similar in geometry to what you are attempting to accomplish. The pistons are 7" stroke, both have a small air tank on the working pressure side attached to each piston. The pistons push just short of over center (they almost line up with the hinge point on the front of the "catapult"). This puts only a slight force on the modified gate latch(not seen on the left side of the picture inside the robot, actuated by a .5" stroke piston which lets go to release the pre-pressurized shooter. The pivot is a pair of door hinges and there is a strap to prevent the pistons from smacking into the end of the cylinders whey they extend.
The gate latch - when your pistons retract, I'm assuming that it locks back into place until the next time you're shooting? Also, do you have the pistons retracting with gravity or some other mechanism, or are you having them retract by sending air in the other side?
Unread 21-03-2014, 00:05
Originally Posted by luckof13 View Post
In addition to what everyone else has said, be sure that you test with 60 psi working pressure as mandated in the rules. Also, I suggest that you include a hard stop before the piston reaches the end-cap of the cylinder to prevent damage to the cylinder.
P.S.
Piston is the thing that moves, while cylinder is the entire actuator.
Thanks for the clarification. I will go ahead and calibrate the system tomorrow so that we are working at the regulated 60 PSI.
By a hard stop, do you mean something to stop the ramp before the pistons make it all the way to the end of the cylinder?
Unread 21-03-2014, 00:06
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
We are using this trick as well, to eliminate unneeded tubing and fittings between the solenoid and the piston to increase flow rate. See this image of our setup; it shows the solenoid valves directly attached to the pistons and how our plumbing is laid out.
Unread 21-03-2014, 00:07
Chris_Ely's Avatar
AKA: luckof13
Yes. A strong strap (like a tie-down strap) would be a good option. You just want to prevent the piston from striking the end-cap with high speed/force.
Unread 21-03-2014, 00:14
s_forbes's Avatar
This is a recommendation I've seen before, and it seems reasonable to me.... however, we have something on the order of 1000 cycles on our practice robot catapult with no noticeable wear or potential failure of the cylinders, and we are using the cylinders with no hard stop. Mind that we avoid dry-firing like the plague, and under normal launching conditions the cylinders aren't hitting their end of travel with such an absurd velocity.
Unread 21-03-2014, 00:31
This is immensely helpful. Thank you.
Apart from having the solenoids connected directly to the cylinders, adding tanks before the pistons, and having them vented to the atmosphere is there anything else you've done to increase you efficiency? While I certainly believe that will help I find it hard to believe that this will bring our dysfunctional setup to working capacity, though I'm certainly going to try.
EDIT: Also, how do the pistons fall back in the cylinder? Does gravity do the work?
Unread 21-03-2014, 00:44
s_forbes's Avatar
The only other big trick is to use a high-flow solenoid valve; we are using McMaster part number 6124K511 to feed each of our pistons. The valves you get from AndyMark or Vexpro flow about 3x less air (these were the maximum flow rate that we could use in the past... this year's rule set has allowed us to use a much larger variety of solenoids).
The geometry of the arm also plays a big role. Based on the videos you posted, I would extend the length of the platform that is shooting the ball, and move the piston locations on the base mounting board back about 0.5"-1" from the pivot location to allow it to sit "flatter" before firing. These pivot locations will all probably need a bit of adjustment as you continue testing.
Oh, and if you can get rid of the miles and miles of tubing between your pneumatics testing board and the catapult, you will probably see an immediate improvement.
EDIT: as far as gravity returning the catapult arm to the starting position, we have never had any trouble with this. It falls right back into place with ease.
Unread 21-03-2014, 00:45
azcalg's Avatar
azcalg azcalg is offline
FRC #1212 (Sentinels)
azcalg is a jewel in the roughazcalg is a jewel in the roughazcalg is a jewel in the roughazcalg is a jewel in the rough
Yep.
Unread 21-03-2014, 02:44
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
All the mentioned changes will help for sure.
Set the cylinders at a better angle.
Since your cylinders are a larger boar and stroke it will need lots of air quickly.
A separate solenoid per cylinder is a must with, if possible, higher Cv flow.
We got these really quickly using one of the vouchers from FIRST.
http://www.automationdirect.com/adc/...)/AVS-3211-24D
They are 24v and the price was reasonable.. About 20 dollars. Not sure if you are using the older 12v solenoid from previous kits. Some FIRST KOP came with 12v others 24v. You will have to make some adjustments if you are running 12v.
You will have to have the solenoid breakout on the cRio run it.
Ideally, like mentioned, mounted on the cylinder. If not as close as possible!
Air lines after the solenoid have to be filled before any air reaches the cylinder.
Storage of high pressure as well as having working pressure tanks for each cylinder. Try having the low pressure tank as close as you can to the solenoid.
As for venting. Take off the unused hose fittings!!! You are reducing the flow of escaping air and slowing it down.
We are running a system similar to 842, ( well done by the way 842!)
(2) 10" 1-1/2"bore cylinders and it will consistently hit the high goal at 20 feet away with a release point of 3.5 feet off the floor..
You can look at our Youtube stuff and freeze frame for ideas..
http://www.youtube.com/watch?v=LfKh6...po3XAn15-6TXDg
Send me a message if you have additional questions. I will try to get some photos from the students.
Good luck this season,
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Division TBD | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 21-03-2014, 02:49
RoboChair's Avatar
AKA: Devin Castellucci
Originally Posted by Joey1939 View Post
You pull the piston in and have it lock in somehow(we use a gate latch).
All glory to the gate latch!!!
Every since I built a 16ft trebuchet for my 9th grade woodshop project I have LOVED using gate latches as a quick, easy, reliable, and cheap release mechanism. Picture Here Additional Info Here
Unread 21-03-2014, 07:28
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
We have found similar results with McMaster 6425k11
There are a large number of teams successfully launching with various length 1.5" Bores, with a single solenoid on each of the cylinders "extend" side and no valve on the "retract" side.
You may want to take a look at the geometry of 842, 624, or 2587.
