Go to Post The way things generally work in cases like this is simple: if you know something, you can't say it. So keep in mind that if someone does say something, it usually means they don't know. - Alan Anderson [more]
Unread 20-02-2003, 00:00
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
Image Discuss: Stack Master
Unread 20-02-2003, 00:03
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
What do you guys think, but before you reply let me tell you that we have 4 wheel drive 2 wheel steering (with the cim motors) the arm is double jointed with a rotation at the base and the clamp is done pnematically, and all the cool lexan covers arnt on it yet(those pics will be up later!!) Please drop a comment on what you guys think of it
Unread 20-02-2003, 01:15
COOPERcable COOPERcable is offline
#1084 (Iron Colts)
COOPERcable is an unknown quantity at this point
Does your arm orient the boxes? Or does it stack it however it picks it up? In your pic you've got boxes stacked every which way, adds up to some wobbly stacks if you ask me...
Unread 20-02-2003, 01:49
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
Wobbly stack or not is not a big deal a stack isnt gonna be moved even if it is stacked in different directions, even if ur stack is perfect or every which way when a robot crashes into it there gonna fall
Hows my searching? Call 1-800-Green-Dots
Unread 20-02-2003, 01:55
#1084 (Iron Colts)
Not necessarily... there are ways to "strengthen" your stack, for example the stacks we will be making barely move at 8 high.
Team 1084 - Iron Colts
St. Clair Robotics Team
Unread 20-02-2003, 01:57
#1084 (Iron Colts)
... besides, when you have boxes stacked like that it limits your max height of boxes. If you have them all aligned perfectly you can go much high as you don't have to worry about balanching your stack because the last box is about to topple your tower.
Unread 20-02-2003, 02:06
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
Although you can grab and stack from any orientation how fast can you do this. What is your strategy if a rampdom gets in your way?
Unread 20-02-2003, 07:58
abeD's Avatar
We can go under the bar, and our strategy isnt soley based on stacking, we can also grab onto a stack and move it wherever
Unread 20-02-2003, 14:35
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
You can go under the bar?!
Looks cool, and similar to my teams robot. vector drive, arm stacking and can go under the bar! Even looks similar, but i think our arm is 2+ feet longer
Team Website
Unread 20-02-2003, 18:33
Perseus's Avatar
Perseus Perseus is offline
Takin' a Break from FIRST
Perseus is an unknown quantity at this point
if u mean u have some sort of stabilizer than yea, of course, but still, if ur not there, ur stack is vulnerable...and even though i havent seen ur bot, i am pretty sure it is possible to knock it down if a bot tried hard enough(just assuming, but i could be wrong..i havent seen it so i really dont know
The Few
The Proud
The Zoroastrians
Unread 20-02-2003, 18:39
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
I'm loving the rubber gloves
Unread 20-02-2003, 22:13
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
well the coolest thing about the way we grab is that we can stack in any which way very quickly , and when we grab the boxes lengthwise we can manipulate it to turn within the grippers sliding into place a lot of times
Its done quick thats all that matters we were more about speed than orientatiton because we know there wion't be many stacks.. but when you can move a stack of 5 over the bar or over the ramp it helps a lot
Dan
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 03-03-2003, 20:53
Powers's Avatar
Powers Powers is offline
#0710 (PAW)
Powers is on a distinguished road
Send a message via AIM to Powers
The robot arm is pretty easy to control after you play w/ it for an hour. After becoming coordinated w/ the robot driver we became able to stack pretty well. and it is really cool to just grab a stack of 6 and drag it over the ramp onto our side, sure the stack falls over, but we still have the top box clamped and ready to stack.
Team 710 PAW Alum
The team that supports the use of the word "Blatantly"
TEXAS WON THE ROSE BOWL
Unread 04-03-2003, 21:47
Powers's Avatar
#0710 (PAW)
Before Pneumatics
Before we put pnuematics on the clamp, we had this nifty system of pulleys, too bad the engineers didnt think it was reliable, i had to cut about 4 pieces b4 i got it right, and now they aren't being used anyway.
Team 710 PAW Alum
Stack Attack Artwork? kmcclary General Forum 3 02-06-2003 10:04
pic: Stack of 7 CD47-Bot Extra Discussion 5 30-04-2003 22:30
pic: 84's Atonomous Stack Slapper CD47-Bot Extra Discussion 2 06-04-2003 22:43
Image Discuss: Paragon 571 with a stack CD47-Bot Robot Showcase 6 21-02-2003 21:50
Initial stack height JJG13 Rules/Strategy 1 29-01-2003 21:04
