Go to Post "It's not a bug, it's an unlisted feature." - Barry Craig [more]
Unread 22-03-2014, 07:24
sasha831 sasha831 is offline
Sasha
FRC #4529 (AI Robotics)
sasha831 is an unknown quantity at this point
Unhappy Window Motors Overheat And Cut
Hello,
We have 2 window wiper motors controlling an up/down arm.
However, once in a while the motor's overheat and cut out for a bit(No more then 30 sec, haven't measures exactly). This is detrimental to our robot's performance. Is there any way, mechanically, electrically or in software that this can be fixed. Keep in mind that we only have one day to alter this, when we get our robot at the regional.
Sasha
Theory is when you know everything but nothing works. Practice is everything works but no one knows why. On our Team, theory and practice are combined: nothing works and no one knows why!
Unread 22-03-2014, 08:14
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: Window Motors Overheat And Cut
The best way mechanically is to change to a versa planetary setup for a move secure and efficient mechanism....
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 22-03-2014, 09:10
April_robo's Avatar
April_robo April_robo is offline
AKA: April Sawyers
FRC #3548 (Robo Ravens)
April_robo is an unknown quantity at this point
We have not experienced this issue and we have window motors on the base of our el toro sticks. I would recommend dropping the power level a little. I would assume this is why we don't overheat our motors
~3548 Alumni (2012-2014)~
~1188/3548 Mentor (2015-Current)~
Unread 22-03-2014, 09:13
Kevin Leonard Kevin Leonard is online now
Professional Stat Padder
Originally Posted by sasha831 View Post
Hello,
Sasha
In general I would use a stronger motor for controlling an arm. Window motors aren't the most reliable equipment.
(2015-Present)
Unread 22-03-2014, 09:42
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Hello,
Sasha
Window motors are designed to move a window of a car up and down (not a big surprise here). Because of that they have a bi-metal autoresetting breaker built in, in case an arm (or other body part) gets caught in the window as it closes. The 'reset' time depends on the heat generated during stall (or close to stall).
If you are insistent on using the window motor in this application, then you should assist the arm when going up (with a gas shock, surgical tubing, etc.) creating a neutrally buoyant arm.
___________________
- Tennyson, Ulysses
Unread 22-03-2014, 09:53
Duncan Macdonald's Avatar
Duncan Macdonald Duncan Macdonald is offline
Globe Motor Fan Club
FRC #0610 (Crescent Robotics)
Duncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond repute
Send a message via MSN to Duncan Macdonald
Quick fixes that don't involve replacement:
Find a way to cool the motors. (add fans or get a can of compressed gas for in between matches)
Make sure your arm is neutrally balanced to reduce the load on the motors. There was a theory that jaguars didn't work well with window motors, not sure if this is true.
If you are controlling the arm with any sort of feedback make sure the motors aren't continuously running to maintain position. (Add a large deadband)
As others have said, this is what window motors do when under load. Replace them if you can.
Queen's Applied Science '13, Applied Mathematics
Unread 22-03-2014, 10:04
The Lucas's Avatar
CaMOElot, it is a silly place
What are you using to control the window motor? Jag, Talon, Vic or Spike?
Spike would be the best since it runs it only full forward, reverse or neutral (same control it was designed for in a car). If you must use a speed controller, Victor would probably be the best due to its lower switching freq.
Robot Inspector
Unread 22-03-2014, 19:10
loyal loyal is offline
Jack of all trades master of none
AKA: Loyal
FRC #0716
loyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to all
Replace the window motor with a PG 71. That is what we did.
