Go to Post Never should an idea be ridiculed, because ideas are exactly that just an idea. - Tim Delles [more]
Unread 22-03-2014, 13:39
Sanchberry Sanchberry is offline
FRC #1466
Sanchberry is an unknown quantity at this point
System can't build pressure!!!
Our pneumatic system is unable to build pressure beyond 60 psi. Whenever we get to 60, our step-down regulator leaks all of the air so that we are unable to store more than 60 psi. When we change the output of the step-down regulator, the pressure of the system changes as well. Basically, the entire system is at the same pressure throughout, and we are unable to store any pressure upstream. This problem was not there on the bagged robot, but it is an issue on the new system we are building. Any help would be greatly appreciated.
Unread 22-03-2014, 13:41
chigskonkwo chigskonkwo is offline
FRC #0884 (Mechanical Mules)
chigskonkwo can only hope to improve
Re: System can't build pressure!!!
Maybe you are using a bad regulator.
Unread 22-03-2014, 13:44
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Make sure that your regulator is plumbed correctly. There is an arrow on the regulator which should point from high to low pressure.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 22-03-2014, 13:52
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Regulators only work in one direction. FRC regulators are relieving pressure, so if the low pressure side is above 60 psi, they will vent the pressure to atmosphere.
Flip your regulator 180 degrees and your problem will be solved.
Art Dutra IV
世上无难事,只怕有心人.
Unread 22-03-2014, 15:22
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
It might not be only 180 degrees, as there are four outputs. To make sure you know which one you're using, look for the arrow on the bottom of the regulator/openings depending on what regulator you are using. Wherever the head of the arrow is where the output has to be.
Good luck with fixing your pneumatics!
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 22-03-2014, 17:41
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
It could also be the relief valve on the compressor. It is adjustable, and could be set too low. It is a screw in adjustment of the end fitting, with a jam nut to lock it in place.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
