Thread Tools |
Rating:
Display Modes |
Re: 2014 Waterloo Regional
Did that last blue low goal score go in or not??
Waiting for the Ref's to decide, It went in the front, then out the side after the buzzer.
I believe it went in through the front, and somehow went out the side. I think that and another penalty is what they are discussing.
That's the debate.
By the rulebook, probably not. It says 'remain completely' in the goal, although it is unclear how long 'remain' means, as I believe the ball was fully in the goal at some point. I presume the delay is someone calling FIRST HQ to make sure the intent of the rule is clear and the actual definition of 'remain completely'. |
That's what the delay is for. Trying to decide that...
Blue wins.
For the record, apparently the goal at the end of the game was not counted. Last edited by brandon.cottrell : 22-03-2014 at 16:01. |
#7
What a match!! Good job to the ref for taking the time to review and reflect!
Cheers!!! |
#8
1114 is having the worst luck with fouls this year.
#9
Eeek. Tough way to go. Getting a 50 point foul from the actions of the other alliances, in which they only get a 20 point foul. By the letter of the law, the calls seem correct, though.
#10
Goal didn't count.
But 1114 just lost because 1241 broke their 'antenna', I don't get it. Isn't there a rule that you can't cause the other team to get a penalty? you penalize 1241 for causing the damage, but ALSO give 1114 a 50 point penalty for being outside 20" frame perimeter. You can't blame it on one team, then give more penalty points to the other team... ugh. Last edited by Jonathan Norris : 22-03-2014 at 16:04. |
#11
#12
This foul will be discussed all week.
#13
There's nothing to discuss though, 1241 didn't do that on purpose - I'm sure even Sims would agree. Tough loss nonetheless.
#14
But a 20 point foul caused a 50 point foul for the opponent. It will be discussed, even though I believe the refs got it right. |
#15
G24 certainly should be called on 1114. Their antenna was >20" outside their FRAME PERIMETER for a continuous time. TECHNICAL FOUL. G27 should be invoked by the "gameplay resulting in damage to opponent ROBOTs" clause. FOUL. G28 should ALSO be invoked by "Initiating... damaging contact with an opponent ROBOT... inside the vertical extension of the FRAME PERIMETER". TECHNICAL FOUL. Last edited by Racer26 : 22-03-2014 at 16:27. |
