Go to Post Wishes and dreams can hold a robot together just as well as nuts and bolts. - Kyle [more]
Unread 23-03-2014, 08:58
Greg McKaskle Greg McKaskle is online now
Re: CRIO ghosting
When your compressor ran unexpectedly, I doubt that the robot was really enabled. Usually, this is either caused by an improperly wired compressor circuit or a faulty digital breakout board that has shorted.
The other symptoms sound like they could be caused by a limit switch that has stopped working. It could be due to wiring or code that doesn't read it often enough.
I can't speak for all engineers, but I don't believe in ghosts. Also, imaging the cRIO seems to have this mystical quality. It replaces the OS and libraries on the cRIO's file system. It is only necessary if the files have become corrupted, and a corrupted OS generally doesn't boot, run, and simply read limit switches differently.
I'd encourage you to debug and diagnose the symptoms independently. Fix what you find and develop good testing techniques for your robot. Things are almost guaranteed to break and become damaged in this game, so being prepared to diagnose and correct is a great skill to have.
Greg McKaskle
