Go to Post ...there's nothing worse than a problem you can't solve because you don't even know about it. - Dave Flowerday [more]
Unread 19-02-2003, 21:57
John H. John H. is offline
John H. is an unknown quantity at this point
Drop Down System
Using a drop down system, we have experienced some problems. Someone on our team proposed asking questions on this forum, so, here I go.
Bear in mind that our robot does not meet the size restrictions. We have implemented a drop down system to fully use our robot.
1) We use two pistons to fall down. One seems to be falling at a different speed than the other. Our robot falls down on one corner, lifts its back high into the air and then drops fully. Consequently, our frame is being bent. How should we solve this problem and drop down smoothly?
2) Our two pistons are connected to a reverse L-shaped bracket/metal piece. This metal piece goes to the end of the size limit. Is there any suggestions for keeping this piece together and weight reducing?
3) Any suggestions for a suspension / any other suggestions?
Thanks a lot for your help.
Unread 19-02-2003, 22:07
grego grego is offline
None #0057 (leopards)
grego is an unknown quantity at this point
pneumatics is just like electricity in that your air (the current) will pass at the point of least resistance. as for solving this problem, i dont know what to tell you. getting 2 pistons to acuate at the same speed is one of the oldest (and toughest) problems in fluid power. all i can say is try and do it w/ one or use a motor instead of pistons. either way theres no quick fix i know of.sorry
Unread 19-02-2003, 22:12
A motor is heavier than two pistons. Also, its a little late to change designs.
Unread 19-02-2003, 22:15
Are you using flow controls on the pistons, and are they set exactly the same?
Unread 19-02-2003, 22:33
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
make sure the little knobs (flow controls) at each end of the pistons are exactly equal
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 19-02-2003, 22:57
We have a "splitter" connected to both pistons with the flow control knobs located on the "splitter". This way the pistons' control knobs would be set equally.
P - Splitter - P
I ............ I
S ............ S
T ............ T
O ............. O
N - Splitter - N
(Sorry for the crude drawing.)
Unread 19-02-2003, 23:25
Another question - Is it legal to work without a compressor?
Unread 20-02-2003, 09:31
Yes it is legal to work without the compressor. Just make sure to remember to charge the tanks before each match
Do the pistons still drop down at different weights when they aren't pushing anything? Try lifting your robot off the ground.
Unread 20-02-2003, 10:07
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Haven't checked up on the Pneumatic Rules recently, but you could possibly run both pistons off one solenoid valve and make sure the tubing leading to both pistons is the same length. That'd be my quick fix.
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 20-02-2003, 11:06
REVving up for a new season
FRC #2848 (All-sparks)
another thing you might want to look at is your weight distribution.....i know that if the cylnders are too small or are just the right size it is possible that you have more weight on one then the other and you are actully pusing the air out of the cylnder with gravity...
I think that I can help you more about your frame bending but I would need to see a picture because that really just means that you arn't distributing your weight enough . rembmer newton for every action there is an equal and opposite reation. what ever force your cylnder is pushing against the floor it is pushing on whatever beam it is attached to...hope this helps
Unread 20-02-2003, 11:33
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
try adding flow restrictors like stated above. Just keep tweaking em till they both extend at the same rate.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 21-02-2003, 21:04
The advice about same length tubing given above is quite sound.
We had a fair size cylinder operating a moveable punch on a large press, with slightly different sizes of tubing, and before it would operate properly the tubing had to be just so.
However, you might want to consider different rates on both cylinders. Just remember to use flow restrictors on only one end of each cylinder - one end's restrictor interferes with the operation of the other.
It was nice to read in the First forums, that First finally admitted you didn't need two/cylinder, mounted on the cylinder as stated in the pneumatics manual, and ignored so successfully.
Unread 21-02-2003, 23:11
erm...
why didn't anyone tell me this...
*packs some regular elbow connectors for cleveland*
DOH!
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
Scoring system for 2004? DougHogg General Forum 11 16-04-2003 20:57
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
