Go to Post IMHO if it was legal a peg leg would be better than a caster. - Edoc'sil [more]
Unread 23-03-2014, 10:12
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Problem with Jags stopping unexpectedly
Greetings,
I am hoping the CD community can help my team with a pesky problem that popped up at the VA regional.
symptom: A drive motor will stop moving. Jag light will switch from green to solid red. The motor will stay unresponsive until roughly half a second after the drive command has stopped. Then resume normal operation. When put on blocks, all drive motors function normally.
What we have done to try and resolve the issue:
1. Replaced Jag. no change
2. replaced PWM wire. no change
3. Swapped PWM wire to another working drive motor on the robot. Problem went to that new motor.
4. changed PWM port via code. no change.
4. replaced DSC. no change.
5. replaced ribbon cable between DSC and CRIO. no change.
6. uploaded code that was working perfectly Friday morning. no change.
7. replaced joystick. no change.
The we have three things we can check now.
a.Replaced the motor on the drive, but that seems unnecessary because of results of #3 on the list above.
b. Replaced CRIO. This is a shot in the dark. Everything thing else on the robot is working as intended.
c. Bad snap action fuse. This is what I am hoping for.
Does anyone have any insights to this problem? We have one last event this week and would really like to resolve this issue quickly.
Help is Chief Delphi. You are our only hope.
Unread 23-03-2014, 10:16
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Re: Problem with Jags stopping unexpectedly
Originally Posted by wilsonmw04 View Post
Greetings,
3. Swapped PWM wire to another working drive motor on the robot. Problem went to that motor new motor.
I can't really offer any advice, but team 1058 had a similar problem throughout the 2012 season. We never really fixed the issue, and we did all of the same things you did. We've since stopped using jags (victors and talons have both worked perfectly for us).
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 23-03-2014, 10:26
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
How are you controlling the Jaguar? Have you tried to measure the current to see if the jaguar is hitting the over temp or over current conditions and shutting down?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 23-03-2014, 10:28
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Greetings,
When you changed to a different motor, was that motor on a different gearbox?
It sounds like you are tripping the overcurrent in the Jaguar. To test upload the default drive code (not a previous version of your code as it may also have the bug) and run it.
It's very possible that somewhere in your code you are giving 1 motor (of a multi motor drive) a different speed command.
___________________
- Tennyson, Ulysses
Unread 23-03-2014, 10:35
If the breaker opens, there will be no lights on the Jag, but it resets almost immediately. If the Jag faults for under volts, over current or over temp, it will fault by turning on the LED RED for 3.5 seconds if the fault has been removed.
Unread 23-03-2014, 10:38
wilsonmw04's Avatar
Coach
Yes. We are running an Octocanum with one cim per wheel pair.
Unread 23-03-2014, 11:09
This doesn't fit all the symptoms you described, but since it's so easy to do:
Try installing the voltage ramp jumper on the Jag that is giving you the trouble.
Unread 23-03-2014, 11:26
wilsonmw04's Avatar
Coach
voltage ramp jumper? I didn't know it had such a feature, I will look into it now.
Edit: wow, that might just do it. I will swap those first thing Thursday. It's worth a shot.
Unread 23-03-2014, 13:09
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
1. Is it possible that the Jaguars are calibrated differently?
2. Rather than running it on a test stand, I would instead simulate pushing during a match by pushing the robot against the wall or some other immovable object (not a mentor) for 4-5 second periods, with a couple second break between pushes. Do it on a carpeted surface so that you have similar resistance to a field. Can you get the issue to happen by doing this over a 2-3 minute period?
3. Per Daniel_LaFleur's suggestion, I'd look closely at your programming to see if you can figure out whether there's a state where you're having drivetrain elements oppose each other. If you don't already have it, consider adding some debugging logic at the point where you are setting the motors. One obvious condition to log would be when the two motors on the same side of the robot are commanded to drive in opposite directions when your grippy wheels are down. Depending on the precise nature of the change you made in #3 this may or may not be the problem.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 23-03-2014, 13:16
Michael Hill's Avatar
We also had the same issues in 2012. We've vowed to never use Jags again and we've never been more happy!
Unread 23-03-2014, 13:21
I agree that this sounds like it is hitting the current limit on the Jaguars, and that the automatic voltage ramp will likely work. VexPro Jaguars (and TI jaguars that have been upgraded with the v107 firmware) have a higher current limit. Is it possible that the working jaguars have the new firmware and the non-working one has older firmware? See http://www.vexrobotics.com/vexpro/mo.../217-3367.html
Unread 23-03-2014, 13:26
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
We are running 4 VexPro jags, and we tried to switch to a brand new jag fresh out of the box and the problem persisted.
Unread 23-03-2014, 13:43
Nuttle89 Nuttle89 is offline
AKA: Ben Nuttle
FRC #5332
Nuttle89 has a spectacular aura aboutNuttle89 has a spectacular aura about
IIRC, even brand new Black Jags ship with the old firmware. I think we had a student flash all of ours with v107 when they first arrived. While updating the firmware might treat your symptom and allow the Jag to function normally, it sounds like you may have some mechanical fault in that module.
I'd recommend swapping the motor leads (post-Jag) and see if the problem stays with the physical motor to diagnose this.
OP, with #3, are you saying you took a PWM line going into the Jag, put it in a different Jag connected to a different mechanism, and that new Jag had the same problem? In that case my best guess would be that you're doing something odd in code like rapidly reversing the motor - this could cause Jags to current fault or otherwise misbehave.
If you do go to the trouble of updating the firmware, the good news is that you can read diagnostic info from the Jag via the BDC-Comm utility. You can manually drive the motor at varying voltage and watch for temperature or current spikes. If you have the cables lying around or can make them, having access to this can be helpful for diagnosing stubborn Jags.
Unread 23-03-2014, 18:28
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Old firmware, new firmware, Jags shouldn't be used for drivetrains (in my humble but accurate opinion). A CIM will pull a little over 60Amps at "ideal torque", which is 150% above the rated Amperage of the 40A Snap-Action breaker. At that level, the breaker will draw that current for over a half-minute without issue. But the Black Jags with the OLD firmware will cut power at 60A after 2 seconds. With the NEW firmware, Black Jags will cut power at 93A. Okay, great, but old firmware versus new firmware doesn't really matter; the Black Jag will STILL cut power if the current draw exceeds 50A "for a short period". This is the "Progressive" software current cutoff in the firmware that isn't really documented anywhere except briefly on the website. Understand that the Black Jag was originally designed for use in applications where you don't necessarily have an external breaker protecting it!
We used Black Jags at Arkansas, and the robot's drivetrain felt very sluggish when starting from a dead stop or when turning (we kept slamming into the current cutoffs). For LSR we're dumping the Black Jags on our drivetrain in favor of Talons (who can handle 60A continuous and over 100A peak without the "progressive" cutoff), but we still are using Black Jags for other areas of our robot where we're taking advantage of the built-in limit switch connections on the Jags themselves; we can protect the robot much faster by killing the Jag directly than waiting for the software to get the message and do it for us.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 24-03-2014, 01:48
geipel geipel is offline
AKA: Mike Geipel
geipel will become famous soon enoughgeipel will become famous soon enough
Danny,
I had heard this sentiment expressed before (about Jags on drivetrains), but this is the first time I had heard it with such a good explanation. This makes sense.
Thank you!
Mike Geipel
