Go to Post This is Chief Delphi. We're all crazy here. - Whippet [more]
Unread 23-03-2014, 11:09
Re: Possible FMS problems.
Canon,
What you describe is typical when the wire strands come out of the WAGO and contact the other polarity. What you are doing is shorting out the power supply on the PD. I would check that you have wired the WAGO correctly when you replaced it. If that is not an issue, then you may have killed the PD power supply. The only repair is a replacement.
