Go to Post Part of FRC and design/engineering is perseverance. Keep your chin up, your thoughts positive, and have respect for your work and the work of your teammates. - Nathan_Fraser [more]
  #46   Spotlight this post!
Unread 03-19-2014, 06:14 PM
Re: Week3 cumulative Twitter stats & OPRs
List of 430 Qual & Elim Matches whose outcome was affected by fouls
From Twitter data 3/16/2014 16:44:46
The usual Twitter data caveats apply.
File Type: xls 430 Qual & Elim match outcomes affected by fouls.xls (164.5 KB, 94 views)
  #47   Spotlight this post!
Unread 03-19-2014, 10:42 PM
Alliance Score Residuals
based on Twitter Qual match data as of Sat 15 Mar 2014 20:56:33 ET.
Example graph interpretation:
81 - 18 = 62% of Alliance Unpenalized Scores were within +/- 20 points of the "OPR" predicted value.
66 - 32 = 35% of Alliance Unpenalized Scores were within +/- 10 points of the "OPR" predicted value.
Attached is a cumulative percent histogram using updated Twitter data 16Mar2014 16:44:46
81.5 - 18.7 = ~63% of Alliance unpenalized scores were within +/-20 points of the "OPR predicted" (L2 norm) value.
  #48   Spotlight this post!
Unread 03-20-2014, 02:52 PM
Key:
  rw:	TRUE if red won the match, i.e. rfinal>bfinal
  bw:	TRUE if blue won the match, i.e. bfinal>rfinal
 tie:	TRUE if the final score was tied, i.e. rfinal==bfinal
  ru:	red final score with awarded foul points subtracted, i.e. rfinal-rfpts
  bu:	blue final score with awarded foul points subtracted, i.e bfinal-bfpts
 ~rw:	TRUE if red would NOT have won if there were no foul points awarded, i.e. ru<=bu
 ~bw:	TRUE if blue would NOT have won if there were no foul points awarded, i.e. bu<=ru
~tie:	TRUE if the score would NOT be tied with foul points removed, i.e. ru!=bu
 rwa:	TRUE if Red's official win would have been altered by removing all foul points, i.e rw && ~rw
 bwa:	TRUE if Blue's official win would have been altered by removing all foul points, i.e bw && ~bw
  ta:	TRUE if the official tie would have been altered by removing all foul points, i.e tie && ~tie
 fao:	TRUE if match outcome was affected by foul points, i.e. rwa || bwa || ta
Last edited by Ether : 03-20-2014 at 03:59 PM. Reason: corrected typo in ~tie and ta
  #49   Spotlight this post!
Unread 03-20-2014, 11:15 PM
Team-by-team analysis of foul points on Win/Loss/Tie
based on Qual & Elim matches from Twitter data Sun 16 Mar 2014 16:44:46
Top "beneficiaries":
Team	wil	wit	liw	lit	til	tiw	WLTnet
4500	6						12
1801	5						10
4779	4	1					9
56	4						8
453	5		1				8
470	4						8
701	5		1				8
1159	4						8
2388	4						8
3070	4						8
3245	4						8
4089	4						8
5065	3				1		7
171	3						6
537	3						6
900	4		1				6
919	4		1				6
1287	4		1				6
2411	3						6
2550	3						6
2811	3						6
3236	3						6
3562	3						6
3619	3						6
4048	3						6
4061	3						6
4114	3						6
4153	4		1				6
4216	3						6
4320	3						6
4375	3						6
4511	3						6
4690	3						6
4970	3						6
5149	3						6
5290	3						6
Top "victims":
245			5				-10
399			5				-10
4776			4	1		1	-10
599			4	1			-9
910		1	5				-9
360			4				-8
488	1		5				-8
1208			4				-8
4654			4				-8
4784			4				-8
5273			4				-8
1094	1		4	1			-7
1806	1		4			1	-7
2642			3	1			-7
116			3				-6
126	1		3			2	-6
144			3				-6
192			3				-6
219			3				-6
435			3				-6
494			3				-6
854			3				-6
955	1		4				-6
1164			3				-6
1302	2		5				-6
1318			3				-6
1477			3				-6
1619			3				-6
1714			3				-6
2073	1		4				-6
2994			3				-6
3063			3				-6
3250			3				-6
3936	1		4				-6
4090			3				-6
4206			3				-6
4245			3				-6
4683			3				-6
4794			3				-6
4815			3				-6
5159			3				-6
5215			3				-6
5252			3				-6
Complete list attached.
  #50   Spotlight this post!
Unread 03-23-2014, 11:52 AM
lf3307 lf3307 is offline
FRC #0885
lf3307 is an unknown quantity at this point
http://www.chiefdelphi.com/forums/sh...7&postcount=11
Thank you, Brandon
Here's an XLS version with practice matches removed
Has anyone located a lookup table with district event codes? and which region each district event is in?
Thanks!
Dan Hudnut, mentor
Team 885, Randolph Ctr., VT
  #51   Spotlight this post!
Unread 03-23-2014, 12:31 PM
http://frclinks.frclinks.com/
  #52   Spotlight this post!
Unread 03-23-2014, 02:20 PM
Besides FRCLinks, you can download the Alliance Selection Spreadsheet and do a lookup there. It might be more convenient then parsing a webpage. For district events, the begining of the name contains the area, ie MI, NE, PNW, or MAR.
  #53   Spotlight this post!
Unread 03-23-2014, 05:25 PM
Week4 Twitter data analyses available here. More to come later this evening.
  #54   Spotlight this post!
Unread 03-24-2014, 10:27 PM
FRC #0885
Thank you both!
  #55   Spotlight this post!
Unread 03-24-2014, 10:37 PM
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Thanks!
Dan Hudnut, mentor
If you need a historical one, I have one posted in CD-Media: Event Codes for FRC Events 2002-2014
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
