Go to Post At least try to make sure other teams are aware of you. Don't be obnoxious, but don't be a wall flower either. - Joe Johnson [more]
Unread 23-03-2014, 22:46
Fej Fej is offline
FRC #1672
Fej is an unknown quantity at this point
Best way to charge batteries
Hey guys.
My team has been having a big problem with dying batteries. I'll cut right to the chase - is there any benefit to charging the batteries more slowly?
We charge all of our batteries on the 6 amp setting. Even the one we got this year dies pretty quick. (They're all Genesis batteries)
We've ordered some more batteries, but we need to know if the charger is going to cause the same problem.
Unread 23-03-2014, 22:49
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Re: Best way to charge batteries
Generally, you will want to charge at the lower rate.
Charging a battery at it's max charge rate will lower it's life.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
I know my team has been eating up batteries like never before this year, but then again we did design a drive train that drew much more power. I guessing based on your question this isn't the case for you guys, because this, naturally, makes a difference. Just trying to clear up the question for more discussion
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 23-03-2014, 23:11
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Yes, definitely. Charging the batteries slower prolong their life. Here are a few tips that I've been told over the years:
(1) Do not deep-cycle the batteries if possible. By "Deep Cycle", I mean don't drain the battery until it's near-dead. Batteries don't ever really fully-recover from being run until they're basically dead, a couple of times of doing this and your battery will never get back to full charge. Fun Fact: Lithium Ion batteries like to explode if you completely drain them and then try to recharge them, so many batteries have a "suicide switch" in them that will prevent the battery from recharging if they get below a set level.
(2) Do not charge batteries while hot. It's best to pull the battery off the robot and just set them aside INSTEAD of immediately putting them on the charger. Give the batteries about 30 minutes to cool, and then put them on charge. You'll get a much better charge on the battery that way. Interesting fact: The difference between a fast charge (charging in 2-4 hours @ 6A or 10A) versus a slow charge (charging in 8-10 hours @ 2A) is heat and gas buildup. Charging a battery quicker causes the battery to heat up quicker while charging, which damages the battery. It can cause hydrogen gas to build up inside the battery and if the gas isn't vented properly can cause a dangerous situation.
(3) If you think your batteries aren't charging properly, check the voltage on the charger itself. It must be charging at a voltage higher than the battery itself in order for the battery to get a good charge. You can detect a dying battery charger by checking its charging voltage.
(4) Never trust the voltage off a recently-charged battery. If you merely test the voltage with a voltmeter, you will be seeing what's known as a "surface charge", you won't actually know how "good" a battery really is. My team really likes a product known as a Battery Beak from Cross the Road Electronics. The bugger is $150, but well worth it. It tests the battery at various power draws, and can show you what the REAL level of the battery is.
(5) If your battery doesn't seem to be charging properly and you've ruled out a bad charger, check the terminals going to the battery. I've seen WAY too many batteries that didn't have a SOLID connection between the wires and the battery terminals, and that can lead to loss of power in charging. I've even seen the connection corroded (rust), that's never good!
(6) Last but not least, never leave a battery on a charger unattended. I've been witness to too many batteries exploding while on charge. Fortunately none of them at FIRST events, but unfortunately the worse ones were at various robotics competitions (mainly BEST Robotics).
Happy Trails.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 23-03-2014, 23:56
My team has been having a big problem with dying batteries... Even the one we got this year dies pretty quick.
You should test the batteries to see if they're shot.
The best way to do this is with a CBA tester. If your team is low-budget there are simple and inexpensive but manual home-brew ways to do the test.
The quickest way to kill an FRC battery (other than dropping it) is to discharge it too completely. The recommended depth of discharge is no greater than 50%. If stored improperly during the off-season, the battery will die a slow but inexorable death.
Unread 24-03-2014, 09:30
ILAMtitan ILAMtitan is offline
Texas Instruments
AKA: Bart Basile
FRC #3005 (RoboChargers)
ILAMtitan will become famous soon enoughILAMtitan will become famous soon enough
If the CBA is out of your price range, take your batteries to AutoZone (or similar auto parts store). They will usually test them for free and let you know if the battery is usable anymore, especially if you tell them what you are doing.
Unread 24-03-2014, 09:49
Not. Autozone does a short-duration high-load test. This does not reliably test the battery capacity, and may damage the battery if done improperly.
http://www.chiefdelphi.com/forums/sh....php?p=1286958
http://www.chiefdelphi.com/forums/sh....php?p=1287478
Unread 24-03-2014, 11:30
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
No it will not damage the battery as it does not apply as much load as the typical FRC drive train and it does so for a much shorter duration.
Unread 24-03-2014, 11:40
"It" depends on the load tester and who is operating it.
Unread 24-03-2014, 22:04
DonRotolo's Avatar
Back to humble
FRC #0832
Generally, AutoZone uses a conductance tester such as a Midtronics, and not like a carbon pile of the olden days. In other words, a LOT like the battery beak. These are very fast, lightweight, and accurate, and do not rely upon the user's skill.
Thhat being said, even a 150A load for 10 seconds will NOT damage an FRC battery. It's not good for this to be done on a regular basis, but 2 or 3 times a year is not harmful.
Unread 24-03-2014, 22:36
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We always charge at 2amp unless we are doing a demonstration where we know we will drain enough batteries to have to reuse them quickly.
I've posted this before and I'm not sure if it's still true, but we were able to get West Mountain to send us an old CBA III for free just by telling them it was for a high school project.
The CBA and Battery Beak allow for you to actually know you have good batteries. Also make sure you have good contacts at the battery terminals, Al recommends star washers between the ring terminal and batter lug and we have been using them with great success the last few seasons. They don't let the connection come loose. Also common sense, never carry or lift a battery by it's leads.
Check the SB50 connections them selves, they can get damaged and hinder battery performance.
Unread 24-03-2014, 22:52
They may be accurate for what they do. But they do not measure the battery's capacity.
I have an old battery in my shed that passes with flying colors when tested with my "125 amps for 10 seconds" tester. But it fails miserably when subjected to a capacity test. So even if the high-load-short-duration test doesn't harm the battery, it doesn't really tell you what the true health of the battery is.
Yuasa NP18-2 datasheet: Maximum discharge: 112 amps.
MK ES17-12 datasheet: Maximum discharge current for 30 seconds: 360 amps.
Go figure.
Unread 24-03-2014, 23:04
Connerd's Avatar
Connerd Connerd is offline
09R - JBD Detachment, USU ROTC
AKA: Conner Doggett
FRC #3166 (First Year Ravens)
Connerd will become famous soon enough
We've been having some issues with batteries this season as well. We use the Battery Beak, check our batteries with the CBA before and after every regional, and try to conserve battery life as much as possible. What I've found, in doing this, is that batteries that are old, and especially have been dropped in any way, are noticeably less reliable, with less charging capacity and amp hours. We get around this by using brand-new (2013+) batteries, and removing them from the roster if they get dropped, until we can test them to find out if they're usable.
<EDIT>
After reading the OP, we charge all our batteries at around 3~3.5 amps. I'll have my captain check me on this, but I do know that we don't like to charge on the maximum amp. </EDIT>
2012-2014 - Team 3245 Ravens, Student/Mascot
2014-20?? - Team 3245 Ravens, Alumni
2015-20?? - Team 3166 Ravens, Mentor
Unread 24-03-2014, 23:08
How many regionals do you attend in a typical season?
Unread 24-03-2014, 23:09
Connerd's Avatar
AKA: Conner Doggett
Typically two, so at least: once before Utah, once after Utah, which is typically coupled with before Las Vegas. Then, if we're lucky, after Las Vegas/ before Saint Louis, or if we're not so lucky, then after Las Vegas. At least 3 times, maybe 4~5 if we're lucky.
