Go to Post Real coaches dont use "strategy assistants" during matches. - Rick [more]
Unread 24-03-2014, 12:40
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: pic: HiGrips after two events
I wonder if AndyMark changed the material since last year. Our team used 4in HiGrip wheels for hours of practice leading up to IRI and through the end of the off-season. We only replaced our back wheels after a fall in the IRI semi finals where they cracked but the middle wheels were put on in June and have been used a lot since then with no where near this level of wear down. We still use that robot for defense on this year's robot.
1058 PVC Pirates 2016 - xxxx
Last edited by BrendanB : 24-03-2014 at 12:48. Reason: This year's kit wheels last year's HiGrips
Unread 24-03-2014, 12:44
Gdeaver Gdeaver is offline
FRC #1640
The wheel behind it does not look as bad. Remember you are in a district comp and have at least 24 matches plus eliminations on those wheels. Also, may be you are under estimating just how much you beat those wheels this weekend. After playing at Lenape, I'm surprised that there is any tread at all. Buy some new wheels and get set for a change out Thursday at Mars champs.Hopefully your design allows for a quick wheel swap. The big question is can one set hold up at MAR because I can say it will be more intense than this weekend.
Unread 24-03-2014, 12:46
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Originally Posted by BrendanB View Post
I wonder if AndyMark changed the material since last year. Our team used 4in kit wheels for hours of practice leading up to IRI and through the end of the off-season. We only replaced our back wheels after a fall in the IRI semi finals where they cracked but the middle wheels were put on in June and have been used a lot since then with no where near this level of wear down. We still use that robot for defense on this year's robot.
Last year's wheels were 6in instead of 4in, so there's 50% more tread to wear away. They were also rated at a slightly lower CoF than this year's wheels, 0.95-1.0 vs 1.1, suggesting that last year's was a softer material. Both are TPU, with the 2013 wheels rated at 77A durometer, the 2014 wheels are not rated on AM's site.
Unread 24-03-2014, 12:47
AKA: Brendan Browne
Sorry, I should have clarified that we used the 4in HiGrip wheels. My mistake!
Unread 24-03-2014, 12:58
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
We knew they would wear down as fast as they did. The four corner wheels are worn smooth but the two center wheels still have about 0.04" of tread left. It is due to the corner wheels being dragged when we turn.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
