Go to Post And whether or not we are awarded in the course of the season, at its end our team will look back, and we’ll look at one another, and we will wonder how we were able to accomplish what we did. - John Wanninger [more]
Unread 24-03-2014, 20:11
andidani andidani is offline
FTC #4970
andidani is an unknown quantity at this point
Re: [FTC]: Servo daisy chain problem
Thanks for the responses, everyone. In the time since I first posted, I found an odd peculiarity with robotc that seems to be the culprit: it seems as though it is indeed impossible for RobotC to properly recognize a servo when used in a daisy chain run through the 4th port, wherein it is not first in the chain. I found this out through simple trial and error, changing nothing but the ports and position of the servo and its controller. My team and I just switched a sensor multiplexer to port four and then put the controller chain in port 3, and voila! Problem solved. Feel free to verify, but at least in my version of robotc (3.62), which should be the latest, this seems to be the only way around the oddly-specific issue.
