Go to Post Smaller FRC bots...... This is what the Mayans were referring to.... My world is ending.... - CrazyHorse [more]
Unread 24-03-2014, 20:53
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Re: Ball Bounces Lands on Top of the Truss
They should just switch to a ball caught on the truss if done "un-intentionally' should be called as a rematch if the ball can't be dislodged in x amount of time by field staff.
Unread 24-03-2014, 20:58
page2067's Avatar
page2067 page2067 is offline
AKA: rick page
FRC #2067 (Apple Pi)
page2067 has a spectacular aura aboutpage2067 has a spectacular aura aboutpage2067 has a spectacular aura about
They should have not had a flat top to the top of the truss! but was an entertaining point of day, and did not affect outcome.
Unread 24-03-2014, 21:05
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
A simple polycarb covering like the high goals would fix this too.
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 24-03-2014, 21:23
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Yeah, except...
Unread 24-03-2014, 21:25
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Originally Posted by BBray_T1296 View Post
A ball stuck on the panel but scored is better because the cycle can then start.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 24-03-2014, 21:36
I am Dave! Yognaut
AKA: Brian Bray
Of course. Having the reset crew fixing something outside the course is 9 million times better than anything on-field, but it still was quite comical, especially considering the purpose those panels were supposed to serve
Unread 24-03-2014, 22:39
Dan_Karol Dan_Karol is offline
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Dan_Karol has a spectacular aura aboutDan_Karol has a spectacular aura about
Send a message via AIM to Dan_Karol
Those panels were there to stop balls from re-entering play after scored. they have nothing to do with causing them to continue through the goal.
2004 - 2012: Team 1100
2013 - ????: Team 131
Unread 24-03-2014, 21:42
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
It could definitely cause a ball to bounce back onto the field after entering the goal, however. That panel should really be angled back to prevent this sort of thing from happening. The truss itself should probably have been made with a triangular cross section to prevent stuck balls there as well.
I also feel that the field should really have been netted as was done last year. The fact that an alliance's single game piece can inadvertently be ejected from play, and that returning the ball to play sometimes requires 3+ people seriously disrupts the flow of the game. FIRST really dropped the ball (failed to drop it?) in terms of field design.
Unread 24-03-2014, 22:12
GaryVoshol's Avatar
GaryVoshol GaryVoshol is online now
Cogito ergo arbitro
The entire netting system and the support poles would be knocked down by a ball going into it.
(since 2004)
Unread 24-03-2014, 21:29
Mrcope9's Avatar
Mrcope9 Mrcope9 is offline
AKA: Matthew Cope
FRC #3991 (KnightVision)
Mrcope9 is a glorious beacon of lightMrcope9 is a glorious beacon of lightMrcope9 is a glorious beacon of lightMrcope9 is a glorious beacon of lightMrcope9 is a glorious beacon of light
We had one match back at Arkansas where our robot launched the ball, it hit the top of the truss and rolled across nearly the entire distance of it before falling off. We watched as it slowly rolled and nearly stopped, but it had just enough gas to make it off. Pretty exciting.
Unread 25-03-2014, 10:14
Dival Dival is offline
AKA: Yarden
FRC #3316 (D-Bug)
Team Role: CAD
Dival is an unknown quantity at this point
Is it so hard to give that panel a 5 deg angle?
Unread 25-03-2014, 22:43
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
These are rented trusses. They are standard fabricated trusses that are used for audio/visual equipment. FIRST does not own them, nor do they build them.
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
Unread 25-03-2014, 23:13
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rotate them 45 degrees then.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 25-03-2014, 23:19
Botwoon's Avatar
The field would be out of spec.
Unread 25-03-2014, 23:25
Gregor's Avatar
Rotate the spec 45 degrees...
<Since 2011
