Go to Post ADMIT IT! Dave Lavery has better legs than Amanda Morrison! - DCA Fan [more]
Unread 24-03-2014, 23:36
Exla357's Avatar
Exla357 Exla357 is offline
Certified Joystick Pusher
FRC #0159 (Alpine Robotics)
Team Role: Electrical
Exla357 will become famous soon enoughExla357 will become famous soon enough
pic: 159's innovative bearing block system
Unread 24-03-2014, 23:38
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Re: pic: 159's innovative bearing block system
That's an awesome idea. Have you found any issues with the blocks drifting slightly and loosing tension under rough play? My team years ago decided to mount our drive train on 80/20 and ended up dealing with the mountings sliding along the crevices and loosing tension.
Unread 25-03-2014, 00:20
Chowmaster4695 Chowmaster4695 is offline
Lathe Master
AKA: Jerry Wright
FRC #4695
Team Role: Tactician
Chowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond repute
Not really necessary or worth it when you can buy this and a bearing block to do the job...
http://www.vexrobotics.com/217-3431.html
Save your resources and time. Its money. Chow out
Unread 25-03-2014, 00:31
Jared Russell's Avatar
Taking a year (mostly) off
I am a big fan of this design. Very clever packaging within the structural member for an 8WD. Cam tensioners work well (see my team affiliation), but aren't always the best choice depending on the other constraints of your design.
Unread 25-03-2014, 00:56
Exla357's Avatar
No issues with movement. Kind of hard to see, but the blocks are secured with pretty large bolts. (As an electrician I have no idea what kind/size they are)
Unread 25-03-2014, 01:11
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Bolt tensioners like this are common in motorcycles. The chain tension provides a force which keeps the bolt from loosening.
80/20 is often a system that uses a clamping forces to hold the material in place which is different than how these blocks function.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 25-03-2014, 06:41
Michael Hill's Avatar
3138 went with a similar bolt tensioning system this year. We also opted to use helicoils (which I suggest). It's worked out pretty well for us so far (provided the drive base doesn't bend and the tension blocks haven't moved). It is rather touchy though. A little bit of rotation goes a long way.
Unread 25-03-2014, 09:24
Monochron's Avatar
Engineering Mentor
Ah, I see. The change in tension is not dynamic for play on the field, it is used for loosening when you want to work on something. Nice.
