Go to Post I would say that you are not an engineer until you've both obtained the aforementioned peice of paper AND done something with your tumescent engineers forebrain. - phrontist [more]
Unread 19-03-2014, 10:14
fireXtract fireXtract is offline
MegaHertz_Lux
FRC #2847 (Mega Hertz)
fireXtract is an unknown quantity at this point
PIDSubsystem works once then disables the entire RobotDrive
I can enable, drive, then use the pid to setpoint my drivetrain, drive somemore but if i reenable the pid it breaks the drivetrain.
 * To change this license header, choose License Headers in Project Properties.
 * To change this template file, choose Tools | Templates
 * and open the template in the editor.
package us.mn.k12.fairmont.robotics.subsystems;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.command.PIDSubsystem;
import edu.wpi.first.wpilibj.networktables.NetworkTable;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
import us.mn.k12.fairmont.robotics.RobotMap;
import us.mn.k12.fairmont.robotics.commands.CommandBase;
import us.mn.k12.fairmont.robotics.commands.DriveWithJoysticks;
 * @author Teacher
public class DriveTrain extends PIDSubsystem {
    // Put methods for controlling this subsystem
    // here. Call these from Commands.
    RobotDrive drive = new RobotDrive(RobotMap.frontLeftMotor, RobotMap.rearLeftMotor, RobotMap.frontRightMotor, RobotMap.rearRightMotor);
    Encoder enc = new Encoder(RobotMap.frontRightEncA, RobotMap.frontRightEncB);
//    Timer timer = new Timer();
    public DriveTrain() {
        super("Drivetrain", 6, 0, 0);
        setAbsoluteTolerance(10);
        enc.start();
    public void initDefaultCommand() {
        // Set the default command for a subsystem here.
        setDefaultCommand(new DriveWithJoysticks());
    public void driveMechanum_Cartesian(double rightJoyY, double rightJoyX, double rotation) {
        drive.mecanumDrive_Cartesian((rightJoyY * -1), rotation, rightJoyX * -1, 0); // Mechanam wheel rollers should form an x when looking directaly down from the top
    public void putPID() {
        CommandBase.table.putNumber("p", 8.0); // change it to smartdashboard getnumber tomorrow when you arent bored of deploying
        CommandBase.table.putNumber("i", 0.0); // HOLY shoot YOU FIXED THE MOMORY LIEEK
        CommandBase.table.putNumber("d", 0.0);
    public double updateStatus() {
        SmartDashboard.putNumber("Enc", enc.getRaw());
        return enc.getRaw();
    public void reset() {
        enc.reset();
        reset();
    public double returnPIDInput() {
    public void setSetpoint(int setpoint) {
        setSetpoint(setpoint);
    public void getSetpoint(int setpoint) {
        getSetpoint();
    public void getPosition(int position) {
        getPosition();
    public void updatePID() {
        RobotMap.p = CommandBase.table.getNumber("p", 8);
        RobotMap.i = CommandBase.table.getNumber("i", 0);
        RobotMap.d = CommandBase.table.getNumber("d", 0);
        getPIDController().setPID(RobotMap.p, RobotMap.i, RobotMap.d);
    public void usePIDOutput(double output) {
        driveMechanum_Cartesian(output, output, 0);
package us.mn.k12.fairmont.robotics.commands;
public class DriveToDistance extends CommandBase {
    boolean go;
    double setpoint;
     * Require the drive train and store the desired setpoint.
     * @param setpoint The desired setpoint for the drive train.
    public DriveToDistance(boolean go, double setpoint) {
        requires(drivetrain);
        this.go = go;
        this.setpoint = setpoint;
    // Called just before this Command runs the first time
     * Set the setpoint to the stored value and enable PID on the drivetrain.
    protected void initialize() {
        System.out.println(this);
        if (go) {
            drivetrain.enable();
            drivetrain.setSetpoint(setpoint);
    // Called repeatedly when this Command is scheduled to run
    protected void execute() {
    // Make this return true when this Command no longer needs to run execute()
     * @return true when it's close enough to the setpoint
    protected boolean isFinished() {
        return drivetrain.onTarget();
    // Called once after isFinished returns true
     * When this command ends, disable the drivetrain's PID
    protected void end() {
        System.out.println("done");
        go = false;
        drivetrain.disable();
    // Called when another command which requires one or more of the same
    // subsystems is scheduled to run
     * When this command exits, disable the drivetrain's PID
    protected void interrupted() {
        end();
 * @author Teacher
public class DriveWithJoysticks extends CommandBase {
    public DriveWithJoysticks() {
        // Use requires() here to declare subsystem dependencies
        drivetrain.driveMechanum_Cartesian(oi.getRightJoyY(), oi.getRightJoyX(), oi.getRightJoyR());
//        drivetrain.drivetest(oi.getRightJoyY(), oi.getLeftJoyY());
        return false;
Does anybody see what is wrong with the code?
Unread 19-03-2014, 10:27
A description of what happens when it breaks the drivetrain would be helpful.
Unread 19-03-2014, 11:39
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Re: PIDSubsystem works once then disables the entire RobotDrive
A couple of things:
First thing, in the initialize function of drive to distance, you should reset the PID. Otherwise the second time you call it the PID isn't zero'd
driveTrain.getPIDController().reset();
Second thing,
This seems wrong. I would assume that you only want to use the output on a single axis of the mecanum drive. I would expect it to be
driveMechanum_Cartesian(output, 0, 0);
Unread 20-03-2014, 09:29
MegaHertz_Lux
A description would be that it spams RobotDrive not updated enough and everything on the robot works except the drivetrain, and I deploying the suggestions of lineskier.
Thanks for the input
EDIT:
[cRIO] edu.wpi.first.wpilibj.networktables2.server.ServerConnectionAdapter@a entered connection state: CONNECTED_TO_CLIENT
[cRIO]
[cRIO] Affirmitive. I read you dave.
[cRIO]
[cRIO] Open the door HAL!
[cRIO] DriveWithJoysticks
[cRIO] DriveToDistance
[cRIO] done
[cRIO] Robot Drive... Output not updated often enough.
And i changed 2 parts
    boolean go;
    double setpoint;
        this.go = go;
        if (go) {
            drivetrain.getPIDController().reset();
            drivetrain.getPIDController().enable();
            drivetrain.getPIDController().setSetpoint(setpoint);
        return drivetrain.getPIDController().onTarget();
        go = false;
        drivetrain.getPIDController().disable();
        end();
 * @author Teacher
        enc.start();
        CommandBase.table.putNumber("p", 8.0); // change it to smartdashboard getnumber tomorrow when you arent borend of deploying
        enc.reset();
        reset();
        driveMechanum_Cartesian(output,0, 0);
Unread 21-03-2014, 09:34
MegaHertz_Lux
I have more detail after playing around with what triggers it.
  1. Deploy code
  2. enable robot
  3. drive robot
  4. press button 11 to activate the DriveToDistance command
  5. robot uses pid to drive robot to the setpoint
  6. command ends and i resume driving and shooting
  7. press button 11 again to reactivate the DriveToDistance command
  8. [cRIO] Robot Drive... Output not updated often enough *100
  9. robot wont listen to any commands related to drivetrain but shooting still works
  10. Disable robot
  11. enable robot, and [cRIO] Robot Drive... Output not updated often enough
  12. Redeploy to fix robot temporarily; until i activate drive to distance twice
Unread 21-03-2014, 10:11
mwtidd's Avatar
AKA: mike
https://www.google.com/search?q=recu...sm=93&ie=UTF-8
Try the "Did you mean".
Now look at this line of code:
enc.reset();
reset();
I'm not going to give you the full answer, but here's a little mod to help you figure it out.
private int i = 0;
i++;
if(i > 1000) System.out.println("Please, please, please, STOP RESETTING ME!");
enc.reset();
reset();
Unread 24-03-2014, 16:58
MegaHertz_Lux
I fixed my recursion error i believe, but its still yielding the same problem.
Output with my comments:
[cRIO] [Squawk VM] Version: 2011 FRC, Nov  5 2011, 14:34:13
[cRIO] FPGA Hardware GUID: 0x1394f6dc1feb42ec6910e5767ed1d22c
[cRIO] FPGA Software GUID: 0xa14c11bde4bb64aef6a86fc52a294cd9
[cRIO]
[cRIO]
[cRIO] edu.wpi.first.wpilibj.networktables2.server.ServerConnectionAdapter@1d entered connection state: GOT_CONNECTION_FROM_CLIENT
[cRIO] edu.wpi.first.wpilibj.networktables2.server.ServerConnectionAdapter@1d entered connection state: CONNECTED_TO_CLIENT
[cRIO] Robot Drive... Output not updated often enough. // right when i enable, what is that all about?
[cRIO] DriveWithJoysticks // i move around the floor and read output from the enc on my smartboard
[cRIO] DriveToDistance //press button 11 and it goes to setpoint 100
[cRIO] done
[cRIO] DriveWithJoysticks //drive around some more and then disable, if i dont disable and reenable same thing happens so it doesnt matter
[cRIO] Open the door HAL! //enable and press button 11
[cRIO] Robot Drive... Output not updated often enough. // here stuff works but not any drivetrain stuff
//////// Here i turn off(physical switch) and turn back on the robot and now it works again!
[cRIO] done
Drivetrain sub
 * @author Teacher
        enc.start();
//    public boolean autoDrive(int dist, double speed) {
//        System.out.println("going fishes");
//        enc.reset();
//        while (enc.get() <= dist - 100) {
////          tal.set(speed*(.1*(dist-enc.get())));
//            if (enc.get() <= dist - 100) {
//                driveMechanum_Cartesian(speed, speed, 0);
//            } else if (enc.get() >= dist + 100) {
//                driveMechanum_Cartesian(-speed, -speed, 0);
//        return true;
//    // credit to team 1160's github for pieces of this
//    public void autoTimeDrive(double time, boolean run) {
//        timer.start();
//        timer.reset();
//        while (run) {
//            driveMechanum_Cartesian(.3, .3, 0);
//            System.out.println(timer.get());
//            if (timer.get() >= time) {
//                driveMechanum_Cartesian(0, 0, 0);
//                run = false;
    public void resetthing() {
        enc.reset();
        driveMechanum_Cartesian(output/4,0, 0);
drive to distance
    boolean go;
    double setpoint;
        this.go = go;
        if (go) {
        go = false;
        end();
Unread 25-03-2014, 09:30
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
It looks to me like your DriveToDistance command will only work one time the way you have it coded. The "go" flag was being set to "false" in the original end() method in the original implementation. Once the flag is set to false, then your drive train PID was never enabled on any subsequent invocation (until you power cycle).
Can you try refactoring it without the "go" flag to something like:
    double setpoint;
    public DriveToDistance(double setpoint) {
        end();
You may also want to add a time out parameter to your command. For example, if you know it should always take less than 5 seconds for the command to complete, set the timeout to 5 seconds to make sure you get back manual control should something go wrong in reaching the set point (like a broken encoder).
Unread 25-03-2014, 09:59
mwtidd's Avatar
AKA: mike
Good catch!
Both of these suggestions look solid to me.
Unread 26-03-2014, 09:37
MegaHertz_Lux
Thank you both, I'm testing this now. I was looking at the documentation on how commands are called and i wasn't sure if the go thing was necessary.
EDIT: IT WORK ZOMGLOLOLOL IM SO HAPPY I LOVE YOU ALL I CAN SETPOINT AS MUCH AS I WANT AND NOMORE ROBOTDRIVE TIMING OUT!!>!>!>!>!>>!!
Thanks lineskier and pblankenbaker! It ended up being the go bool and I'm looking into the timeout thing. I'm so happy because we go to competition today, and i can make code for the main robot now!
