Re: Acquiring 120 tooth 9mm HTD belts
All,
This was a bit of an oversight/late realization on my part, when we next reorder the pulleys for 15mm wide belt they will be sized such that 2x standard 9mm wide belts fit on them. It was a late idea that RC from WCP had to fit double belts and we solved it by adjusting the tolerance to drop to 8.5mm wide. As Ricky said, they will be back in stock soon. -Aren |
We have 120T, 9mm belts - along with a few others of both 9mm and 15mm - back In Stock now.
http://www.vexrobotics.com/htdbelts9.html |
