Originally Posted by vinnie
How good is the support for standard Linux programs, do you think it might be able to run ROS?
The most recent image I've tested is an older Angstrom distribution. In particular, it uses an older libc6 (2.11), which makes it a little difficult to use the most recent packages (many of which require 2.12), but I have successfully installed gdb, gcc, python and other packages with careful use of opkg install --nodeps. I have not tried installing ROS in particular, but there's no fundamental reason it can't be made to work even if the out-of-the-box packages don't.
For example, here's a tutorial on NI's website that installs PostgreSQL and uses it with LabVIEW on the Linux platform:
https://decibel.ni.com/content/docs/DOC-30308
Author of
cscore - WPILib CameraServer for 2017+
Author of
ntcore - WPILib NetworkTables for 2016+
Creator of
RobotPy - Python for FRC
2010 FRC World Champions (
294, 67, 177)
2007 FTC World Champions (30, 74,
23)
2001 FRC National Champions (71,
294, 125, 365, 279)
