Go to Post Darn kids, how can they not be addicted to ChiefDelphi? - Kyle Love [more]
  #106   Spotlight this post!
Unread 19-03-2014, 13:25
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Al's Annual Inspection Thread
Originally Posted by philso View Post
Thanks again for your help, Al.
I studied the Game Manual, Team Updates and Q&A, several times before working this out and will be watching out for the items in your comments. I had not seen any teams putting sheet metal between the bumper wood and the frame so I wanted to make sure we weren't going to go down the wrong path.
Phil
Here is an in depth look at our bumpers this year. They held up really well.
http://blog.spectrum3847.org/2014/03...d-bumpers.html
  #107   Spotlight this post!
Unread 23-03-2014, 08:54
DRH2o's Avatar
DRH2o DRH2o is offline
AKA: Dan Waters
FRC #1598 (Team Talon)
DRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of light
The Virginia Regional did a wonderful job with inspections this year. With all the snow this year in areas that are not used to it there were a lot of unfinished robots. They had inspectors that came to you, or you could go to an inspection area. When there were a handful of teams not inspected Friday morning, inspectors took chairs to their pits to be there and answer questions. GREAT JOB Tom and crew -- especially Chuck - my kids called you Santa
  #108   Spotlight this post!
Unread 25-03-2014, 23:23
I would like to remind everyone of the rough game that were are playing this year. If you are playing in your first event this weekend or next, do not be surprised if your robot inspector points to items he would like to see fastened to your robot. In particular, the bumpers and the battery. Batteries are receiving as much external damage from hitting items inside the frame as they would from a drop. Bumpers are hit so hard that many mounting systems are failing. Remember that under G20, a robot can be disabled should the bumpers fail during the match. I have had several teams tell me that their bumpers failed in spite of their using the "lift test" described elsewhere.
I also want to remind teams that any changes, no matter how small, you make to your robot must be reinspected. If you add something or take something off, we need to know what the new weight is and we need to inspect the change to be sure structural integrity is good and no other items have been compromised. This reweigh helps get you through final inspection quicker and helps us get through all the teams prior to alliance selection. This is a very serious issue, without the reinspection, you are playing with a un-inspected robot. Many teams are taking off shooters and adding ballast to become a better defensive robot. These changes are often done in haste and therefore without regard to the effect it might have on other robot functions. Let your inspection team be your eyes and ears as they can look at your robot with a little clearer vision and help you get the design you are trying to achieve. We really want you to win. We feel we are part of your team.
There have been two very clear issues with teams this past week. One is the mounting of the plastic tanks on arms and moving appendages of the robot. Not only is this a poor choice for air flow (the tubing length is excessive), it exposes the tanks to hits from other robots. Excessive current causing power to brownout on the robot. This can bring about temporary loss of the radio, full reboot of the radio and/or cRio, fault conditions on Jaguars and shutdown of digital I/O and DSC. Be sure all primary wiring (battery, main breaker and PD input) is tight, both crimp and screw terminals and the hardware. This is a real issue for teams running inefficient drive systems.
Good Luck Everyone.
  #109   Spotlight this post!
Unread 26-03-2014, 00:04
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
Al -
Could you elaborate on how LRI's have been advised to handle a robot with an air tank mounted this way at upcoming events?
- Ron
Team #2607 controls mentor
FIRST Mid-Atlantic Volunteer
FRC Team #2607 Mentor
  #110   Spotlight this post!
Unread 26-03-2014, 08:09
Ron,
It is wise to move it down inside the robot away from the possibility of it getting hit. I would like LRIs to try and convince the team of the risk of such mounting. When a team uses air as part of their ball handling or shooting, loosing that air will put them out of business for the remainder of the match. Even something as simple as a hose getting pulled out will have that effect. The plastic tanks may fail if hit hard with a metal arm on another robot or in a collision. It doesn't violate any specific robot rules, it is just bad practice.
  #111   Spotlight this post!
Unread 26-03-2014, 08:11
nathannfm's Avatar
nathannfm nathannfm is online now
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Al,
Could you give guidance on a mounting system like this, mainly the part in red: http://screencloud.net/v/8UUP
The green parts are our robot / frame perimeter, everything else is BUMPER. We have used the wing nut/stud method before so I am not worried about that. My main concern is the (red) aluminum 2.5x1 angle that rises above the top of the bumper. Everything remains in the 2-10in bumper zone, but I have never seen an attachment method that went above the bumper itself in recent years. I can't find a rule this would violate and our own LRI, Brian Lucas, says it's fine, but this really seems like it's pushing it. I just wanted to get a second opinion before we start cutting metal.
Thanks.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
  #112   Spotlight this post!
Unread 26-03-2014, 09:27
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Originally Posted by nathannfm View Post
Al,
Thanks.
I won't attempt to comment on the legality, but I'd be concerned about how the 2.5x1 angle attaches to the wood. That seems like the weak point. Bolts through the wood are a necessity. Screws won't cut it.
  #113   Spotlight this post!
Unread 26-03-2014, 09:53
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Al,
Thanks.
So long as the top of the red portion is completely within the bumper zone, I don't see a problem with it passing - it looks like a legal method of attachment (provided all other bumper rules are met, of course - for example, we can't tell from the image how often it's attached, or if there are gaps between the bumper and the frame)). I will caution: This is a very hard hitting game. I could potentially see the bumper rotating into the red piece, causing it to bend. I would recommend having something in place, like vertical supports on the robot between the two frame sections, to prevent the bumper from rotating when hit.
2016: Lake Superior WFFA
  #114   Spotlight this post!
Unread 27-03-2014, 17:37
nathannfm's Avatar
AKA: Nathan
FRC #3940
Thanks for the replies, we do comply with all other bumper rules, looks like we will be going ahead with this modification.
I know, we have used hammer in thread in the other end of the wood for many years and they hold up well, the only problem is that when we want to modify their location we need to unwrap it which is a pain.
  #115   Spotlight this post!
Unread 27-03-2014, 18:51
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Looks to me that the bumper is more than 5" tall that way if the red part comes off with the wood backing. Unless your bumpers are already at the 10" height you may want to duplicate the lower angle stock so that the two angle (gray) pieces extend in above the lower green tube and below the upper one. Then slide the wood up a little to give good connection basis for the gray pieces.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
  #116   Spotlight this post!
Unread 30-03-2014, 20:43
Nathan,
I would agree with Jon' assessment of the picture you provide and reiterate the violent nature of this game requires the need for secure mounting. However, I have not seen this method used before and it would be best to ask the Q&A for the definitive answer.
  #117   Spotlight this post!
Unread 18-04-2014, 19:18
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Inspection at Championship will be just like at any of your regionals.
If we find something wrong, that was missed at your regional, PLEASE don't tell us that "This robot passed XXXX Regional."
We are all human (though I'm not to sure about Big Al ) and we miss things. Please remain calm and we will do everything in our powers to get your robot passed to play Thursday.
No Robot Left Behind.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
