Go to Post IS THAT A CLUE, DAVE?!?!? - Joe Matt [more]
Unread 26-03-2014, 11:51
one_each one_each is offline
FRC #4057 (KB Bots)
one_each is an unknown quantity at this point
Re: Question about converting RS232 to TTL
Originally Posted by yash101 View Post
Excuse my kinda curious nature, but I debug my RasPi using a serial UART connection. I just wire the TX and RX backwards and it works. What is the difference between UART and TTL? Aren't they a similar protocol?
The RasPi and VEX Cortex's UART are using the same voltage levels (3.3V). The GPS is using RS-232 which runs at 12V and would fry the VEX. The MAX3232 chip converts the voltage levels so the two can talk without damaging anything.
Unread 26-03-2014, 12:17
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Just to be clear:
UART is 'Universal Asynchronous Receiver Transmitter' and is a hardware peripheral on microcontrollers used to implement a bit-serial interface. It is essentially the hardware that serializes and deserializes bits from a serial bus into bytes, and handles clocking. It by itself has no voltage, that is dependent on the implementation.
TTL is 'Transistor-Transistor Logic'. Usually this is defined so 0-0.8v is logic 0 and 2.2-5v is logic 1, so 3.3v and 5v are both acceptable voltages although some 3.3v devices do not tolerate 5v. TTL is a digital signal spec, it does not define what the digital signal is.
RS-232 is a standard which uses +-12v as logic 1 and 0. It defines the signal voltages, timing, and connector. The timing can be generated by a UART.
RS-422, RS-485, LIN, and several other physical layer standards also use UART with a different physical transceiver. The signaling voltages are different, but the timing is the same.
Kettering Motorsports
