Go to Post Data is never ugly. It is only how you use it that can be. - Ed Law [more]
Unread 26-03-2014, 15:49
regulated power for potentiometer
Apologies if this question has already been discussed in detail in another thread. A quick search returned no helpful results.
What is(are) the recommended way(s) to power a potentiometer so that the signal is less affected by battery voltage change?
Would it be helpful (and legal) to tap into the power going to the radio?
Or perhaps do A/D on both the signal and the power to the pot, and use the ratio?
Unread 26-03-2014, 15:54
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: regulated power for potentiometer
I believe the converter on the Analog Breakout is pretty good at handling low battery voltages. My experience with it is limited, so YMMV.
It's definitely not legal to connect anything to the radio power slot but the radio/radio converter.
Unread 26-03-2014, 15:57
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
That's a good question. I know our code last year used "getAverageValue()" and seemed to be very consistent - our arm (controlled with 3 pots - shoulder and elbow using 270 degree pots, and winch using a 10-turn pot) didn't seem to be affected by power, at least not until the power got so low the motor on the winch couldn't get the robot all the way up. In our build space testing, we saw no visible difference in how the arm operated when going from a dead battery like that to a fresh, fully charged one.
2016: Lake Superior WFFA
Unread 26-03-2014, 15:59
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
It's very easy to add a jumper to the analog board and read in the supply voltage. Since it's a 0.1" pin header, you can just use a standard 0.1" jumper between the center (5v) and signal pins.
That's probably the easiest way to do it.
Kettering Motorsports
Unread 26-03-2014, 16:02
The Analog Breakout has an LDO 5v linear regulator, good to about 5.6 volts. Do you know a team who is getting that low consistently?
Unread 26-03-2014, 16:04
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
Us. At least this appears to be the problem.
-Aaron
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 26-03-2014, 16:09
cgmv123's Avatar
AKA: Max Vrany
-Aaron
Do your driver station logs show you getting that low in a match?
Unread 26-03-2014, 16:13
I wasn't suggesting connecting anything other than the 12-to-5 converter to the PDB regulated 12v.
Unread 26-03-2014, 16:16
cgmv123's Avatar
AKA: Max Vrany
You also aren't allowed to power anything but the wireless bridge from the regulated 12v slot. [R43]
Unread 26-03-2014, 16:21
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
Toward the end of some matches, yes.
Unread 26-03-2014, 16:52
If you're having trouble with the Analog Breakout, the Digital Sidecar isn't far behind, with much worse symptoms. It might be helpful to make a new thread about how you're killing batteries over the course of a match, and describe your robot and power systems so that people can provide suggestions on how to reduce power draw.
The dropout of Analog Breakout regulator decreases as the load decreases. You may be able to reduce the number or size of loads to gain a little more margin. See attached chart from the MIC5209 datasheet.
I agree with Max that you can't tap into the radio power supply in any way.
One option, without adding an external boost converter, is to use power a Solenoid breakout with cRIO 24v (allowed per R42). Turn on a Solenoid Output (allowed per R51), and then use a voltage divider to bring it down to 10v (The NI analog module is +/-10v). This has the disadvantage that you can't read the pot during disabled mode. You're also switching from a linear regulator to a switching regulator.
Unread 26-03-2014, 17:01
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Could you wire the positive terminal of the potentiometer to the 5v port on the PDB? I'm not sure how low of a battery voltage it takes to brown that port out, but I don't see anything against it in the rules.
I'm right 90% of the time, so why worry about the other 3%?
Unread 26-03-2014, 17:09
yash101 yash101 is offline
AKA: null
Can't you use the voltage regulator for the camera? I think that is legal
Unread 26-03-2014, 17:23
Stephen.Yanczura's Avatar
Stephen.Yanczura Stephen.Yanczura is offline
opportunist
FRC #0195 (Cyberknights)
Stephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to all
I'm shocked that you're having this problem and we have not run into this. My team has a penchant for using a TON of motors (13-15) and at least 3-5 pots each year and we haven’t run into this. Plus our driver drives like a bandit and we have our 6 CIM drive geared to the moon this year so I know we're sucking some serious juice out of the battery. We do buy ten brand new batteries every year and use a freshly charged battery every match which helps us.
Any major mechanical inefficiencies in the system?
Are all your crimps and terminals good? Anything getting super warm?
Have you tried swapping the analog breakout?
stephenyanczura
team 0195 | 2010-Pres. | cyberknights | Conn. | mentor
team 0195 | 2006-2007 | cyberknights | Conn. | mentor
team 1660 | 2005-2006 | harlemknights | NYC | mentor
team 0195 | 2001-2005 | cyberknights | Conn. | student
s.j.yanczura@gmail.com
Unread 26-03-2014, 17:56
It may just be old batteries.
Aaron, when's the last time you guys capacity-tested your batteries?
