Go to Post If there's one bit of advice I can give, its never underestimate the power of a hurricane. - Joshua May [more]
Unread 26-03-2014, 17:21
EliStevens12 EliStevens12 is offline
FRC #4925
EliStevens12 has a spectacular aura aboutEliStevens12 has a spectacular aura about
Zip Tying Motor Controllers onto Robot?
Hi my FRC team was wondering whether or not there were any specific rules that prohibited us from securing our motor controllers with Zip Ties?
Unread 26-03-2014, 17:25
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Zip Tying Motor Controllers onto Robot?
There are not specific rules that prohibit this.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 26-03-2014, 17:26
JohnFogarty's Avatar
AKA: @doctorfogarty
There are no rules prohibiting this practice. It's not exactly recommended you do so though I usually end up doing it on my really basic test robots and electrical boards.
John Fogarty
Unread 26-03-2014, 17:51
nxtmonkeys's Avatar
nxtmonkeys nxtmonkeys is offline
SCP-682
AKA: Parker Wells
FRC #5349 (RoboEagles)
nxtmonkeys will become famous soon enough
If you have really really really good zip ties, and you remove the ends, you should be fine. If you can bolt the motor controllers down instead, then do so if you want to. If you do use the zip ties, bring plenty of extra for that just-in-case scenario.
Good luck!
Unread 26-03-2014, 18:13
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
We zip tie our controllers every year. Fast, light, easily moved. Have never had a problem.
Unread 26-03-2014, 18:32
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Likewise. Motor controllers aren't particularly heavy, and zip ties are more than sufficient.
Unread 26-03-2014, 18:37
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Generally speaking, motor controllers don't experience much force, if decently protected.
Also, the wires (generally larger gauge), will assist in the retaining of the controller, as long as your crimps are properly done (or soldiered [as in wire to crimp, not ever crimp to MC, before I get hounded])
This year our electronics are fairly out in the open because there is literally nowhere else to put them. In our 1st match of Dallas a ball landed squarely on our right side electronics board, ripping out the (poorly crimped and not soldiered) right side drive motors and even SNAPPING A FAN IN HALF.
In the past we used plastic hardware to screw the MCs down to some corrugated plastic, which you can poke mounting holes into with just a precision screwdriver, so our mc mounting is hardly robust, yet we have never had a problem.
Zip-ties are nice for those on the "no velcro and no hot glue on the motorcontrollers" bandwagon, because they are 100% removable and allow for easy swapping of MCs if it becomes necessary.
Unread 26-03-2014, 18:54
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
We zip tye down almost all of our electronics and we have yet to have a single fail even though we play a very defensive position.
http://i.imgur.com/Dpd0TtK.jpg?1
An advantage of using zip tyes over bolts is that they will fail under heavy forces that would normally damage the electronics if they were bolted down.
2016: FRC 865 Mentor
Unread 26-03-2014, 20:30
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
We've been using nothing but zipties on our motor controllers with complete success since 2006 , when we discovered that Loctite dissolves the plastic cases and they fall apart .....
2007 - Rookie All Star - Bayou Regional (1858 - Tyborgs)
2009 - Rookie All Star - Bayou Regional (2992 -Prometheus)
2010 - Champions - Bayou Regional (2992 -Prometheus)
2012 - Finalist - Bayou Regional (2992 - Prometheus)
team2992.com/design.php
Unread 26-03-2014, 21:52
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
There are no rules that disallow it, but there are better methods. Personally, I prefer industrial Velcro. Its a godsend for making quick repairs (i.e. electronics swapouts).
Unread 26-03-2014, 22:47
Lucario's Avatar
Lucario Lucario is offline
AKA: Alan
FRC #0422 (Mech Tech Dragons)
Team Role: Operator
Lucario is on a distinguished road
I like Dual-Lock even better. That way, you only need one roll on hand, and I think it's even stronger than industrial Velcro. It also keeps things from wiggling around, too.
Unread 27-03-2014, 09:10
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
We go even further to cut out our belly pan with all the mounting holes for ALL of the electronics and proceed to thread the holes of the .090 plate. I used the Hole Wizard tool in solid works to give all of the holes the proper dimension and then we thread them as soon as the plate gets back from the laser sponsor. The holes don't even need drilling before we tap them. After the holes are tapped we bolt everything to the plate with plastic machine screws and then cut off the excess bolt with a pair of dikes. Super Simple after the cad is done. However. If we decide we need to add things later Zip Ties, are our number one choice. So zip ties work very well.
Unread 27-03-2014, 09:56
mman1506's Avatar
no team (WARP7)
We've always had issues with the backs of victors and spikes falling off when we Velcro them down.
Unread 27-03-2014, 10:17
AndreaV AndreaV is offline
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
Sounds like you are using too much. Usually when I Velcro I try to use two thin(.25-.5) strips. Just enough so that when it's removed the bottom plate dosn't stay behind.
2005-2006,2011 FRC 865 Warp7 Student, Mechanical team
2013 FRC 1310 RUNNYMEDE ROBOTICS Mentor, CAD and Manufacturing
2014-2015 FRC 5031 Downsview Robotics Mentor, Design and Manufacturing
2016-Present FRC 1360 Orbit Community Robotics Mentor, Design and Manufacturing
Unread 27-03-2014, 10:49
loyal loyal is offline
Jack of all trades master of none
AKA: Loyal
FRC #0716
loyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to all
Zip ties ftw imo
