Go to Post In the end engineering is what happens between your ears, not what you build with your hands, not what a machine spits out. - KenWittlief [more]
Unread 26-03-2014, 22:36
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
Re: 11th Hour Question about pneumatic catapult piston arrangement
Originally Posted by hzheng_449 View Post
Our team has the same 2-pistons quasi-parallel to arm setup that the previous post mentioned though we have slightly less range and height.
I don't have any pictures of our setup offhand, but if your interested I might be able to dig up a few.
It's worth noting that our design requires a high flow solenoid in order to get enough power to the pistons in order to make a shot. If you don't have any, a work around would be to have one solenoid feed to each piston and have them fire simultaneously in code.
We actually have a high flow solenoid feeding each of our pistons, though these just arrived today and were not used in obtaining the numbers for the test above; those came from 1 of the old grey solenoids from 2006(?) feeding each cylinder.
Unread 26-03-2014, 22:48
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Please people they are not called pistons, they are cylinders!
