Go to Post work hard, think hard, and have fun doing it. - ebarker [more]
Unread 27-03-2014, 17:10
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
pic: Low Profile VEX Ball Shifter
Unread 27-03-2014, 17:11
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: pic: Low Profile VEX Ball Shifter
Are those motors driving bevel gears or a worm gear?
EDIT: Nevermind, helps when you read the whole post.
Unread 27-03-2014, 17:12
Dr.Gusta's Avatar
Team Role: CAD
They are driving bevel gears
Unread 27-03-2014, 17:46
Mitchell1714's Avatar
Mitchell1714 Mitchell1714 is offline
What's better than robotics?
AKA: Mitchell Schlidt
FRC #1714 (MORE Robotics)
Mitchell1714 will become famous soon enough
This is really cool. This looks very similar to 192's gearbox from 2012. It might be useful to contact them on their design.
2016-present: 1714(Alumni)
2011-2015: 1714(Student, FRC)
2013-2015: 1714(Student, VEX)
2006-2011: 1714(FLL)
Unread 27-03-2014, 18:34
JeremyLansing's Avatar
JeremyLansing JeremyLansing is offline
Team 967 Alumni
FRC #0171 (Cheese Curd Herd)
JeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud of
Do you have any higher resolution photos or CAD models you are willing to share? I'm intrigued and would like to dig a little deeper into how you designed these.
2015 Midwest Regional Finalists (Thanks to 2338 and 1756)
2014 Central Illinois Regional Finalists (Thanks to 4143 and 2039)
2013 Curie Division Semifinalists (Thanks to 2056 and 3990)
2013 North Star Regional Champions (Thanks to 2175 and 4607)
2011 10,000 Lakes Regional Champions (Thanks to 525 and 3642)
Unread 27-03-2014, 18:44
Dr.Gusta's Avatar
Team Role: CAD
I would be willing to post the CAD just as long as everyone knows this is still very much a work in progress and as it sits right now it will not work but the basic design is correct. I will pack up my files and upload them to google drive now.
Unread 27-03-2014, 19:14
Dr.Gusta's Avatar
Team Role: CAD
Here is the link. My file origination is a mess right now but open Gear-box.iam and that should give you the most up to date assembly.
https://drive.google.com/file/d/0B7j...it?usp=sharing
Unread 27-03-2014, 19:41
Team 967 Alumni
Thank you so much. I can appreciate the fact that it is a work in progress, and I was mainly hoping to take a look at how you had the insides of the gearbox arranged. Best of luck to you with finishing the design!
Unread 27-03-2014, 23:55
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
My first though was, what bevel gear are you using. More importantly have you found one you plan to use or is it still theoretical.
Having experimented with this kind of space saving, we eventually came to the concussion that the most efficient method is to flip the motors around. 971 did this in '12 and '13 and our ball shifting gearbox copied that this year. (The most similar example may be Texas torque's gearbox from last year, I believe it was a vex ball shifter with custom plates so the motors hung over the wheels)
That said, I really like this and the out of the box thinking behind it. It reminds me of the things I thought about when planning 192's '12 and '13 gearboxes. I've worked with right angle drives, the construction technics you seem to be using and bevel gears so let me know if you have any questions.
Unread 28-03-2014, 00:33
Dr.Gusta's Avatar
Team Role: CAD
I am glad you like it and as for the bevel gears I am using CAD files from here (http://www.qtcgears.com/KHK/newgears/KHK228_2.html) the CIM bevel gears are a bored out and key way broached "Pinion Shaft" as called on the website and the larger bevel gear is drilled out and broached to a 1/2" hex, so some modification will be needed but nothing beyond the range of a FIRST team with decent manufacturing capabilities. Working on getting everything lined up and working then I will go through and make it look pretty because we all know that counts
