Go to Post I can't think of a match where we didnt do the ritual. We always called it... "Deploying the code" - Briansmithtown [more]
Go Back   Chief Delphi > Technical > CAD
Unread 28-03-2014, 18:22
WIREDFTC's Avatar
WIREDFTC WIREDFTC is offline
More hot glue!
FTC #5035 (WIRED)
Team Role: Webmaster
WIREDFTC has a spectacular aura aboutWIREDFTC has a spectacular aura about
Re: Full AM14U Long Chassis Inventor CAD
Originally Posted by Austin Veseliza View Post
Sure!
http://i.imgur.com/2z9BCid.png?1
This is a view from a corner, but you can see how the chassis is tilted vertically at roughly 35 degrees.
Okay! I am assuming all your parts are constrained together, but if they aren't, then this will probably not work.
On the part browser on the right, open the folder named "Origin", right click on the piece labeled XZ Plane and click on visibility. Then constrain a flat surface on the bottom of the chassis (or whatever you want to be parallel with the bottom of the space) to the edge on the now visible plane. This should make it parallel to the bottom, and then just undo what you did first to hide the work plane again.
