Go to Post Johnny V-Neun. People just want to be his kind of cool... none of us really know why... - Pamela [more]
Unread 28-03-2014, 18:43
alexander.h's Avatar
alexander.h alexander.h is offline
Lead Programmer, Captain, Driver
FRC #3975 (The Dragons)
alexander.h has a spectacular aura aboutalexander.h has a spectacular aura aboutalexander.h has a spectacular aura about
Beginner Java Help - Question 1
Hello! I'm new to Java (we're planning to switch to it next year after passing the last three years using Labview) and I have one important question. In the "Getting Started with Java for FRC" pdf, it shows the following code for an autonomous that drives in a square pattern by driving half speed for 2 seconds, then turns 90 degrees. This is repeated 4 times :
public void autonomous() {
     for (int i = 0; i < 4; i++) {
          drive.drive(0.5, 0.0); // drive 50% fwd 0% turn
          Timer.delay(2.0); // wait 2 seconds
          drive.drive(0.0, 0.75); // drive 0% fwd, 75% turn
     drive.drive(0.0, 0.0); // drive 0% forward, 0% turn
What I don't understand is why it's a 75% turn for a 90 deg turn? Is there some way this was calculated?
Thanks!
P.S. I called this "Question 1" because I know that I will have other questions about Java in the future!
2012 - Rebound Rumble - Montreal Robotics Festival - Qualified 15th - Semifinalists thanks to 3379 and 3710 (Record : 8-8-1)
2013 - Ultimate Ascent - Montreal Robotics Festival - Qualified 33rd - Dean's List Finalist : Yazid Djenadi (Record : 4-8-0)
2014 - Aerial Assist - Montreal Robotics Festival - Qualified 9th (Record : 6-4-1)
2015 - Recycle Rush *** I predicted the game ***
Unread 28-03-2014, 18:55
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Re: Beginner Java Help - Question 1
I doubt it was calculated. It is just a code example so try not to read too much into it.
It was probably reduced to control speed of the turn. But paramters on your test chasis will be different.
The take away from the example is to show how to set individual motor speeds, and performing time based waits.
Hope this helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 28-03-2014, 18:56
Hope this helps,
Kevin
So, for one robot, it could be o.6, but for another, it could be 0.8?
Unread 28-03-2014, 19:20
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
It also depends how far you're driving. The smallest amount of rotate will cause the robot to go into a circle. If you want to truly move in a 90 degree line, you have to rotate 90 degrees than move forward.
E/ nvm misread it.
0.75 has nothing to do with the degree of the turn. When the move value is 0, the robot will stay in place.
However, a rotate will cause the motors to run in opposite of each other, essentially turning the robot. 0.75 for 0 seconds (thats what the code says... rotate for 0 seconds) might be + or - depending on the weight of the robot and the condition of the battery.
Unread 28-03-2014, 19:27
Controls Engineer
AKA: Kevin
Yes that is correct, you will need to play with the paramerts to achieve the turn you want based on your particular robot. The % will be based on the weight or the robot, # of motors on each side of your drive train, type of motors, and a couple of other paramters which describe the dynamics of your particular bot.
The example is open-loop, which means it turns without sensors, once you get the example working, dont worry too much if it the turn is not accurate or repeatable.
The main thing here is to make sure you understand the logic of what the code is doing.
After which, try adding sensors to make the turn more repeatable like encoders on the drivetrain, or gryo or digial compass if you would like to stick with this example and enhance upon it.
Hope this helps,
Kevin
Unread 28-03-2014, 19:35
Hope this helps,
Kevin
I get it know ... thanks!
