Go to Post Courtesy is the key. - Tom Schindler [more]
Unread 28-03-2014, 23:37
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
Re: pic: Next Revision
Originally Posted by sanddrag View Post
What's your source and spec on the bevel gears?
I got them from here (http://www.qtcgears.com/KHK/newgears/KHK228_2.html) the CIM bevel gears are a bored out and key way broached "Pinion Shaft" as called on the website and the larger bevel gear is drilled out and broached to a 1/2" hex, so some modification will be needed but nothing beyond the range of a FIRST team with decent manufacturing capabilities.
Unread 29-03-2014, 00:46
Rauhul Varma Rauhul Varma is offline
Drivetrain and Design Lead
FRC #0192 (GRT)
Rauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud of
Originally Posted by wasayanwer97 View Post
Your construction technique is similar to 192's gearbox from 2012, but you currently don't have any hard connections. If you look at theirs (though I'm no expert on it, I've just seen pictures) they still have some bolted connections.
The plates on our 2012 drive gearbox were all press fit together, however we did have 2 bolts running through the gearbox to clamp it shut incase the presses ever came loose.
I don't know if OP will be coming, but I'd sure love to see one of your 2012 gearboxes. It's one of the coolest gearboxes I've ever seen.
I've run into a myriad of different issues while attempting to design my own worm drive, so seeing how you guys were able to accomplish it would be amazing!
I’ll be bringing our 2012, 2013 and 2014 gearboxes to SVR
If you need any help with your worm drive gearbox I’m sure Joey Milia would love to help.
Unread 29-03-2014, 01:48
wasayanwer97's Avatar
wasayanwer97 wasayanwer97 is offline
Take from the best, invent the rest
AKA: Wasay Anwer
FRC #0668 (The Apes of Wrath)
wasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant future
That's so awesome! Thank you so much!
Can't wait to stop by 192's pit.
"Coming together is a beginning; keeping together is progress; working together is success."- Henry Ford
FRC Team 668: The Apes of Wrath
Pioneer High School, San Jose CA
http://www.theapesofwrath.org
Talking to other FIRSTers is great. Add me on Facebook!
My Page
Unread 29-03-2014, 03:29
Dr.Gusta's Avatar
Team Role: CAD
Okay here comes V3, some of the bearing holes became overly sized for some reason and they will be an easy fix but I want to go to bed lol. I also need to add a 3:1 third stage to correct the ratios because as of right now they are way too high. It also now mounts to the KOP frame through 4 tapped holes on the face that line up with the toughbox mounting holes. Let me know what you think.
STEP: https://drive.google.com/file/d/0B7j...it?usp=sharing
Picture: https://drive.google.com/file/d/0B7j...it?usp=sharing
Unread 29-03-2014, 13:32
AKA: Wasay Anwer
V3 is looking good!
A few things though:
1. To make facemounting easier, I would go one of a few routes: Put the four bolts holding it together in through the back and tap the front plate (this would give you a flush, flat front) or I would use countersunk bolts on the front instead. The other option is to just have holes for the bolt heads to fit through on the spot you're mounting this. Generally, your mount will be a lot more snug and reliable if the face is right up against the surface you are mounting it to.
2. You probably already know this, but just to remind you, you're going to need another spot for a bearing on the front plate if you intend to add a third stage.
This is a beautiful, elegant gear box. Awesome job on it!
My Page
Unread 29-03-2014, 14:14
kghaemi96 kghaemi96 is offline
Driver/Know-it-all/Engineer
AKA: Kevin G
FRC #2637 (Panthers)
kghaemi96 is an unknown quantity at this point
Originally Posted by lonnie lascelle View Post
Is it possible to put both motors on one side so that you can reduce the overall width? Make one motor horiz and the other under it on an angle - same site.
I agree with what you're saying. this is an awesome gearbox, but it would take up a lot of space.
Why not both? ¿Por qué no los dos?
2011 Las Vegas Regional Semifinalists (5th Alliance Captain)
2012 Las Vegas Regional Semifinalists (2nd Alliance)
2013 Inland Empire Regional Quarterfinalists (7th Alliance)
2014 Central Valley Regional Quarterfinalists/Creativity Award (7th Alliance Captain with 2085 and 5136)
2014 Los Angeles Regional Semifinalists (4th Alliance Captain with 696 and 5102)
Unread 29-03-2014, 15:49
Dr.Gusta's Avatar
Team Role: CAD
V3 is looking good!
Yeah I did not think about the bolt heads getting the the way I will have to go and fix it but the I add the third stage I will have to face mount to thag any way. The reason I have yet to add the third stage and another bearing because I am not 100% sure how to do it but I will figure it out . As for saving space I am making this box with the intention of making it easy to tuck away and less awkward so I could mount the motors closer together but I choose not too. Thanks for the feedback.
Unread 29-03-2014, 22:18
AKA: Wasay Anwer
If you need any help with the third stage, just let me know. I'd be more than glad to help.
My Page
